Acura winter Rims
Acura winter Rims
Does anyone know if rims from a 95 Legend (16 inch 114 bolt pattern) will fit on a 2001 Cl Type S. I assume they will but am wondering if anyone has mounted older Acura rims as winter tires. I currenntly have a set of 16 inch steel rims and a friend of mine has a set of used rims off a 95 Legend I can use if compatible.
I think the Legend Rims will fit, but I’m not sure.
I thought I remember someone putting CL-S Rims on a Gen II Legend Coupe a while back.
I myself use a set of 16” Rims from a 2000 TL for my winter tires.
Shawn S
Shawn S
Sweet as Gold
Yeah we've put CL-S rims and TL-S rims on on second gen legend...they bolt right up except you have to slightly bore out the hub on the cl rim to get it to fit...which means the Legend rim hub bore will be slightly larger than the hub on the CL...but as long as you properly tighten and torque your wheels you will be fine. You can even buy some small spacers from your local rims shop and that would work too. Good luck@!
merc009
10-03-2015 12:59 AM
