Acura oil filter is tiny!!!!!
I can't believe it. I'm getting ready for my first do-it-yourself oil change on my 6Speed and wanted to make sure I could access the filter and the drain bolt. I read many posts on oil changes so I jacked the car up and took a look. THE FILTER IS TINY! I can't believe Acura is using such a small filter. I'm going with a Mobil 1 or Fram x2 filter.
Can anyone tell me the size of the drain bolt?
Amsoil sdf44 large and works / fits just fine. mobil1 also good choice,,, both $10 to $15 range but you are paying for the tested best,,, marketing and commercials will have you believing $3.00 frams are the best hummm.. skimp now if you change very $3k miles and use petro oil. I use synthetic and change every 10k miles. My lab analysis after 10k says oil is at 6-7tbn, new petro oil is 6-8tbn (this is very basic) but it proves the point, if you want the best it's available. Do a little internet research.
Originally Posted by paulff3
Fender, so you are not a fan of the Fram X2?
http://www.ntpog.org/reviews/filters/filters.shtml
Fram has a very high production run and it's hard to insure they don't decontent their products,,, IE some of their filters are made with cardboard and some arn't. I stick to one product that is made the best and they don't have a lower product line.
You'll be ok with fram for 3-4k oil changes... extended changes you might what to use the best. I still change the filter every 5k. I keep my cars for 200k miles and most synthetic used truck engines are being torn down at 400k and show hardly any wear.
I am not sold on amsoil I just haven't found anything that independently tests better. Ester oil is better but it's 30 / qt. Most people know this oil has the special addition you put in posi track rears.
asahrts
Sep 4, 2015 05:55 PM
