Acceleration question on the Koni yellows
Old Jul 26, 2002 | 07:25 PM
Red Rider's Avatar
Subie Dubie
I adjusted my Koni Yellows a half turn before a recent twisties run and maybe it's a coincidence, but since then on several quick spurts i've chirped the tires where i can barely remember ever chirping them before. Does this make sense ? Is there a correlation between firming up the struts and what i'm seeing with the chirps. Thanks.
Old Jul 26, 2002 | 07:31 PM
Rescuer's Avatar
Evil Bob Knieval
i think your tires just got more worn out from driving so damn fast with me about 2 feet from the rear of your car at the last Sac meet
OR you stopped on the crosswalk line and chirped upon acceleration
Old Jul 28, 2002 | 10:31 AM
Red Rider's Avatar
Subie Dubie
Thanks, that must be it !!!
Old Jul 28, 2002 | 10:33 AM
Red Rider's Avatar
Subie Dubie
Any one else with a comment ?
Old Jul 28, 2002 | 08:04 PM
AztecRol's Avatar
The Screeching Toyo's
I will adjust mine to VERY SOFT as they are VERY STIFF right now. I will let you know what I think!!!
Maybe you are just flooring it a bit more lately????
Maybe after driving the MDX, you get in your car and press the gas just a little harder than normal cause you are used to the MDX gas pedal???
Old Jul 28, 2002 | 08:05 PM
frederix's Avatar
I think the firmer you make the shocks the less you will chirp the tires because the car will resist transfering the weight from front to back. I adjusted mine to full stiff one time and I could not feel the car move back and forth when I shifted.
Old Jul 29, 2002 | 04:22 AM
fbazakos's Avatar
on bin laden
i leave mine at 100% tight in the front, and about 90% in the back ... but I only drive on the weekends and the track. it is perfectly balanced given the rest of my suspension. oh, and the related note, i can't chirp my tires worth a damn.
Old Jul 29, 2002 | 08:14 AM
johntypes's Avatar
koni
i chrip my tires all the time my shocks will be installed this week i am hoping to not have weight tranfer i want it as tight as possible
Old Jul 29, 2002 | 08:33 AM
mlrspwr's Avatar
at 50% stiff, I have less "chirping" than ever. People are amazed at how well the car handles high-speed curves and turns now.
I can say that I have much, much less squeal and chirp on the high speed turns and curves.
Old Jul 29, 2002 | 09:10 AM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
Worn tires.
Old Jul 29, 2002 | 11:08 AM
Red Rider's Avatar
Subie Dubie
Thanks for all the replies, it doesn't sound like adjusting to firmer would give me more chirping based on the responses. Maybe i'm just lead footing it more, if that's possible
Old Jul 29, 2002 | 12:34 PM
H@mmerm@n's Avatar
My other car is a 350Z
Bro, I think you're using more right foot, and less left foot, if you know what I mean. :P
Old Jul 30, 2002 | 11:24 PM
Red Rider's Avatar
Subie Dubie
Well, it's only rubber
jblessing
Aug 8, 2018 09:43 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
CLsuperhero
Sep 23, 2015 12:53 PM
heykosal
1G RDX Problems & Fixes
Sep 21, 2015 09:41 AM
datadr
Sep 12, 2015 09:12 PM
