Acceleration
Acceleration
Stolen from another car forum:
A lesson in acceleration:
First, some useful info:
*One Top Fuel dragster 500 cubic inch Hemi engine makes more horsepower than
the first 4 rows at the Daytona 500.
*Under full throttle, a Top Fuel dragster engine consumes 1 1/2 gallons of
nitromethane per second; a fully loaded 747 consumes jet fuel at the same
rate with 25% less energy being produced.
*A stock Dodge 426 Hemi V8 engine cannot produce enough power to drive the
dragster's supercharger.
*With 3000 CFM of air being rammed in by the supercharger on overdrive, the
fuel mixture is compressed into a near-solid form before ignition. Cylinders
run on the verge of hydraulic lock at full throttle.
*At the stoichiometric 1.7:1 air/fuel mixture for nitromethane the flame
front temperature measure 7050 degrees F.
*Nitromethane burns yellow. The spectacular white flame seen above the
stacks at night if raw burning hydrogen, dissociated from atmospheric water
vapor by the searing exhaust gases.
*Dual magnetos supply 44 amps to each spark plug. This is the output of an
arc welder in each cylinder.
*Spark plug electrodes are totally consumed during a pass. After 1/2 way,
the engine is dieseling from compression plus the glow of exhaust valves at
1400 degrees F. The engine can only be shut down by cutting the fuel flow.
*If spark momentarily fails early in the run, unburned nitro builds up in
the affected cylinders and then explodes with sufficient force to blow
cylinder heads off the block in pieces or split the block in half.
*In order to exceed 300 mph in 4.5 seconds, dragsters must accelerate at an
average of over 4g's. In order to reach 200 mph well before half-track, the
launch acceleration approaches 8G's.
*Dragsters reach over 300 mph before you have completed reading this
sentence.
*Top Fuel engines turn approximately 540 revolutions from light to light.
*Including the burnout, the engine must only survive 900 revolutions under
load.
*The red-line is actually quite high at 9500 rpm.
*The bottom line: Assuming all the equipment is paid off, the crew worked
for free, and for once, NOTHING BLOWS UP, each run costs an estimated $1,000
per second. The current Top Fuel dragster elapsed time record is 4.441
seconds for the quarter mile (10/5/03, Tony Schumacher.) The top speed
record is 333.00 mph (533 km/h) as measured over the last 66' of the run
(9/28/03 Doug Kalitta.)
Putting all this into perspective:
You are riding the average $250,000 Honda Moto GP bike. Over a mile up the
road, a Top Fuel dragster is staged and ready to launch down a quarter mile
strip as you pass. You have the advantage of a flying start. You run the
RC211V hard up through the gears and blast across the starting line and past
the dragster at an honest 200 mph (293 ft/sec.) The "tree" goes green for
both of you at that moment. The dragster launches and starts after you. You
keep the throttle hard open, but you hear an incredibly brutal whine that
sears your eardrums and within 3 seconds the dragster catches and passes
you. He beats you to the finish line, a quarter mile away from where you
just passed.
Think about it, from a standing start the dragster had spotted you 200 mph
and not only caught, but nearly blasted you off the road when he passed you
within a mere 1320 foot long race course.
That folks, is acceleration!
sentence.
load.
just passed.
And to think that tire technology is a limiting factor and that they are doing this without direct electronic control (they do have data acquisition for post run analysis though). To put this into perspective; 0 - 60 MPH occurs in about 0.5 seconds with 100 MPH coming up in under a second.
With better tires and electronic controls it is thought that 3 second range ETs could be achieved at over 400 MPH. But at that point the human limits seriously come into play.
Great info!
Someone was talking about the power of the current F1 engines (whos?) 900+HP, and some commented how one of the Top Fuel guys commented on how they made more power in one cylinder.
And…
“Carl knew of Don Garlits and Joe Amato, but really wasn't sure why they were no longer driving. I explained to Carl that the G-forces a Top Fuel driver experiences while accelerating off the starting line, and when stopping the car with the chutes, are almost equal to that of an F-16 pilot. After many years of driving a Top Fuel car these G-forces begin to affect the drivers body with symptoms of back and neck pain, along with damage to the eyes. The eye damage occurs when the car suddenly begins to stop with the pulling of the chutes. The drivers head lunges forward severely as the car begins to stop but his head is still moving forward. This can cause the retina to slowly begin to separate from the eye and eventually cause blindness. Both Don Garlits and Joe Amato had this condition, and despite surgery with hopes of correcting it, their doctors advised them to stop driving. Knowing this, Luigi has chosen to pull one chute, and then the other if needed. This reduces the G-forces and the severity of movement to the drivers head, thus reducing the amount of possible damage to the retinas.
And…
Cost Drivers!!!!
Re: Great info!
And…
And…
true but F1 engines are N/A and have much less discplacement. The functionality of each engine is also entirely different.
Where is my super sauce?
Re: Re: Great info!
You aren't going to get a top fuel dragster to do 3gs around a curve at Indy (at least in its current state).
Form and function -- hey?
Re: Great info!
Re: Re: Great info!
Originally posted by pgt89
I pulled 9.4G's on an F-16C Block 30.
Originally posted by Chemmech
pgt89, how about some incentive flights for the guys on the board ?
Forgot, F-16 is a single seater .
Hey pgt89, ever come up to Dobbins AFB.
Re: Re: Great info!
Considering the Top Fuel guys probably make, on average with testing, two to three WOT run per week. Do pilots get to push the planes to this extreme this often?? I know the pilots are generally in better shape but can they stand the loads better due to this.
I've seen guys come back after incentive flights, most of them lose their cookies .
Re: Re: Re: Great info!
Originally posted by scalbert
But that brings up an intesting question; who pulls these high of Gs more often??
Originally posted by [DWI]
talk about tunnle vision . . .
Re: Re: Great info!
pgt89, I'm prior Air Force, don't laugh but I used to work on A.G.E. equipment at Travis, then onto Alaska with the 54th. F15-c models, man I miss hearing those things starting up and taking off, especially the F15-E models, since they take off with their afterburners on . It makes your heart rattle in your chest, aaahhhh :P .
Lead Footed
Nice post . .
Being there to experience these beasties either one (TF/Dragster or a fighter jet) is a treat. I've done both going to school at a fighter base in Germany . . the F15 had just come out and the runway was about less than a 1/2 mile from the school. And the CEO's daughter of the last company I was with ran TF.
Something else to experience is the pits when they are tuning them . . . nothing like nitromethane fumes in your eyes and nose. :'(
The closest to experiencing that kind of G-force was on the Titan at Six Flag over Texas . . . it supposedly gets over 4Gs. I believe it as on the 2nd helix I began to see black spots . :P I don't think I could take 6Gs without blacking out . . but many pilots wear a pressurized suit to help keep the blood in the brain so they don't pass out under those extreme Gs.
Ruf
Ruf
Censored User
Location: Miami - just one day, I would like to drive without getting cut off!
mlody
12-04-2019 02:11 PM
joflewbyu2
08-18-2019 10:38 PM
