ABS pump
1 Post
ABS pump
a lil while ago my VSA lights and ABS light would come on and then go off, well now they stay on and the dealer says the ABS pump is bad and wants $930 to fix it...anyone else had this problem? or have any other sugestions?
i am having the same problem, but it is intermittent, the lights only go on about 1 or 2 times every two weeks. They told me the pump was about $700 so with labor i guess it would be right up there. They said my case may be due to the wires, they noticed it looked like a rodent had chewed on them a little so next time its in they are going to tape them all up and see if that works. If not, i will let it go, its getting traded in next spring anyway most likely.
See Chief F1 Fan's threads:
https://acurazine.com/forums/showthread.php?t=168350
https://acurazine.com/forums/showthread.php?t=168420
https://acurazine.com/forums/audio-video-electronics-navigation-22/din-kit-now-available-174578/
He's the only one I can remember reporting a problem (except for you 2 guys in this thread)... I guess there's 3 members with ABS modulator issues.
https://acurazine.com/forums/showthread.php?t=174578
Jamus22
06-11-2023 10:08 AM
IBankMouse
06-13-2020 12:53 PM
