7500 RPM redline...
#82
THE J35A2...
Originally Posted by mrsteve
I think 9,000 RPM may be a little overkill on these platforms
At that RPM on this motor the mean piston speed would be (slightly) greater than that found on a Honda F1 motor and faster than a Honda S2000 motor.
if you ask me it's still possible to get 9kRPM. ofcourse with engine mods... upgraded cams, valve, retainers, rockers, springs, etc... stroke and bore too, which will not be talking about J32 engines anymore maybe that's why you said it's overkill for this engine as far as i know we have some of those stuff above mention similar to S2000s' where there is an aftermarket support... to make everything more complicated, fooling the ecu for the rev limiter
#83
You wouldn't want to increase the stroke any more. That's what is going to increase the piston speed at 9,000 RPM.
The J35 internals at 9,000 RPM would travel nearly 28m/s vs a F1 engine which travels at 25m/s
#84
THE J35A2...
#85
The issue becomes friction between the piston and the cylinder walls.
I'm telling you, if Honda decided they needed to lower the redline on the AP2 S2000 because the increase in stroke was causing the piston to move too quickly at 8,900 RPM I wouldn't doubt they had good reason to do so. No need for you to go exploring an uncharted territory when the outcome is predisposed for failure.
#86
THE J35A2...
i thought it was hp issue reason why they did that
i thought horsepower becomes an issue due to vibration that it creates, spark and the heads aren't working properly due to vibration that's why the engine's power is not upto par... they can solve that problem and stayed 9Krpm but they decide not to because it adds up to the price of the car...
i guess you're right, this just giving me a headache, i'll just buy a faster car
#87
Originally Posted by CleanCL
no way his redline increased from the gauge cluster. ECU controls that. as far as gaining power from a higher redline in n/a application... i'm still a bit skeptical. all of my dynos peak and then drop. i am n/a, but forced induction may be another thing all together.
#88
watched his video ...i dont know looks like 6500 maybe 6600 fuel cut starts ...if 6300 is redline ? whats fuel cut anyone know ? im starting to loose faith... i always believed the ecu got the signal from the wheel speed sensor this is why people will dyno 6800+ rpm s fuel cut when going with tire that are 234/45 a slightly shorter sidde wall... whereas the tach shows the 7100 ...hard to say at this point ...but ive always belived it would be fairly simple to trick the ecu into delaying fuel cut by finding it's trigger...rpm gauge/wheel speed sensor or other...
#89
Originally Posted by typeR
dont be so quick ! there's no doubt the ECU does it ! but where does it get the info? if there's a trigger from the rpm gauge then this makes perfect sense...maybe the kids vtec has been changed to but it would be to the 4800 rpm close enough to this 4600 that he's saying based on noise
As for can the motor handle more rpm, yes. This motor is limited for many reasons, and the one I can tell that is a problem are the valve springs. There set up for about the advertised red line.
#91
Moderator Alumnus
Originally Posted by NightRider
CLp redlines at 6300 per Acura specs.
#92
When i get home thursday i can throw in my P gauges and see what happens???
#94
i just think this is funny. you guys think the ECU adjusts according to the tach on the dash...
from the electrical manual:
"The tachometer drive circuit (part of the main circuit) receives pulses from the PCM. The solid-state tachometer then displays these pulses as engine speed. For each 200 pulses per minute from the PCM the tachometer displays 100 RPM."
so, we have learned, the tachometer display receives it's signal from the powertrain control module. my guess is that the TP sensor is linked to the ecu. the ecu for the type s is told it's higher redline, when TP sensor reads the certain value, it tells it to fuel cut. this is the simplest explanation imo.
#95
No it doesn't have anything to do with making too much horsepower. It had everything to do with piston speed.
#96
2600lb CL
Maybe we can just put out the math problem for everyone to see? I have it at home...
#97
Originally Posted by Cocoa
MrSteve is 100% correct. I never bothered to do the math as to what it came out to, but I was always iffy about those that wanted to raise the fuel cut off without doing the math that's involved. Me, stroking it to a 3.5L, naturally cannot go as high as whatever the highest rpm the 3.2 can go. Also, for those of you that are familiar with K series, piston speed is the reason as to why those that do the K24 short block with the K20a head has a lower redline than the K20a long block alone. Because of the raised stroke.
#98
#99
The formula is:
Stroke*2*(RPM/1000)/60
The piston speed on a F1 car is about 25m/s
The piston speed on a AP1 S2000 is 24.9m/s
The piston speed of a AP2 S2000 is 24.1m/s
The piston speed of a J32A2 @ 7,2000 RPM is 20.6m/s
The piston speed of a J32A2 @ 9,000 RPM is 25.8m/s
The piston speed of a J35/J32 Hybrid at 7,200 is 22.3m/s
#100
The formula is:
The piston speed of a J35/J32 Hybrid at 7,200 RPM is 22.3m/s
#101
so the reason for this thread is to gain some knowldge too ...if your saying the tach receives the info from the ecu for rpm,thats fine doesnt completely discount that there could be a trigger in the tach to respond back when fuel cut should be initiated...now tps i dont see it cause you could reach fuel cut at only 25% throttle
There is one easy way to solve this. A scan tool hooked up to the OBD2 port and run to WOT. It will show the max RPM
#102
i think the new 3.5HR for nissan has similar stroke and bore and they go 7500 from the factory
The stroke on the VQ35HR is 81.4mm.
The stroke on the VQ37HR is 86mm just like the J32A2.
They both have a much larger bore @ 95.5mm
So the piston speed on the VQ35HR @ 7,500 RPM is just 20.35m/s
#103
there is a test tachometer plug. it is in the engine bay. it is on the strut tower almost directly underneath the throttle/cruise cables, and to the left of the orange plug that is always in the way of the icebox installs.
p.s. i see no other circuit going from the tach back to the PCM.
#104
#105
so to sum this up... block signal from tach to ECU to stop fuel cut? if it is coming from the tach... I think it's purely the ecu causing fuel cut, but the ecu ignores engine speed and gets it's info from something pre-programmed into it to make it shut off at 7100. I don't think it gets it's info from the tach. if the tach effected fuel cut that would mean vtec would only engage if the tach was in a specific position but I think the ecu keeps up with everything and when to kick it in.
I know this sound ghetto but I know basic resistors have been used to block ecu signals in most cases causing a higher rpm idle speed. No real power made there but something to note. what's different about the wires in the CL-P cluster and CL-S cluster? Could it be the amount of electric current traveling through the wires that fools the ecu? I don't want to completely shoot this down but I dunno.
#106
Somethings I would like explained:
What exactly was swapped out? Was it only the plastic gauge face?
Can someone please post a picture of a CL-P tach gauge and a CL-S tach gauge?
#108
Moderator Alumnus
Originally Posted by CLsuperhero
Not the best pics but it's something I think it's a type S
http://cgi.ebay.com/ebaymotors/01-03...QQcmdZViewItem
#110
OMG
why would the ECU rely in a grossly INACCURAGE GUAGE when it can use the Crank Position Sensor to figure out RPM? Based upon this insane logic those with broken tachometers would never redline becuase the tac would never reach the switch.
Fuel cutoff is PROGRAMMED INTO THE ECU along with TOP SPEED GOVERNOR
Please, pull your head out of your rear end long enough to think about what you just said.....
The only way to change redline or fuel cutoff is to rewrite the code with the new values for each......lol
want to know why the tach is off? most likely becuase it is calibrated for the CL-S versus the CL-P
tach is controlled by a voltage signal that is sent to it
lets say that at redline the ECU sends 12V to the tach on the CL-P it is calibrated for 6300 and on the CL-S it is 6800. swap a CL-S tach into a CL-P and bingo tach swings to 6800 even though it should read 6300. I would guess that if you did the reverse swap the CL-P tach would redline at 6300 in a CL-S
#111
Originally Posted by YeuEmMaiMai
OMG
#112
#113
well you sound like you must have all the answers... so why then if it was the crank postion sensor DUMB ASS would the car dyno different rpms when wearing different size tires ... why would a coil clamp read 6880 rpms when wearing 235/45 tires and 7150 with 245/45 ? regaurdless the ECU is getting the signal from somewhere clamp that out put and one could have any redline or none... you may wanna read things like the title right below my user name and maybe my join date and sig... then sit back give respectful insight or you may just find yourself taking alittle break from this site ! read that
#114
#116
Lead Footed
Originally Posted by TheWeez
If it's redlining a whole 600RPMs higher I think you may want to either put the old one back in or get it checked out. Your engine isn't likely designed for that higher redline. The CL-S has a higher compression and other changes made to allow the higher redline. Also, what does the car idle at now?
This is a Honda engine and its trademark is high reving engines, and I will bet that this engine will handle 7,500.
Ruf
#117
I Wanna Beer
So to summarize.
Everyone agrees that there is no way that changing the gauge cluster changes the actual redline and VTECH engagement. It's just an off gauge or the difference in spacing on the CL-P cluster vs the CL-S cluster.
The engine can likely handle a higher RPM then the factory redline but won't likely benefit unless it's FI. It would need modification to do so such as UPDs and some kinda management to allow it to push past the factory fuel cutoff.
#118
Lead Footed
OMG
Your points have merit, but they are lost in the off color commentary BS.
I've been working on cars off and on for over 30yrs and have seen some weird @ss $hit designs, so anything is possible. However, while this does seem unlikely it is an anomaly worth checking out and I believe that is all TypeR is doing.
Ruf
#119
Moderator Alumnus
typeR is my hero.
I don't agree with this statement. Lets say you're hypothesis is wrong, the CL-S ECU sends the signal to a CL-P tach, I would think that it would show that the tach would hit 6800 every time, not 6300. Who's to say though, if you think you're right, show us and prove us wrong.
#120
SOLD
Ok I tested out the rpm reading on the vtec controller several times in first and second gear...I took it to 7100 and shifted, and also let it hit the rev limiter a couple times (boo), the max rpm reading at 100% throttle did not break into 7000 ever.
If 7100=6900 then can it be assumed the tach is 200rpm off? Seems the ECU knows what it's doing...
Couldn't get any video, my brother jacked my camera yesterday
