6MT launch
Old May 11, 2006 | 05:59 PM
leolebo28's Avatar
Drive FAst and Swirve
6MT launch
Going to the track tomorrow, wanted to see if anyone with 6MTs had any advice especially on what rpm's to launch at
Old May 11, 2006 | 06:32 PM
typeR's Avatar
i do have advice...youre gonna use the hand break and try to hold 4000 rpms with that at the line forgetting about the tree at first and the person beside you i want you to hol the hand break up and realse the clutch just enough that you feel it just starting to engage but not enough to move it against the hand break around the time the second yellow light on the tree has come on (assuming sportsmen tree) and im not talking about the staging lights but when the tree has started it's count down release the hand break and give alittle more clutch and a little more gas slow feather each trying to maintain this 4000 rpm w/little to know wheel spin...most bad wheel spin occurs from the suuden shock of the clutch engaging...pre loading it and feathering it just right should produce the best results
Old May 11, 2006 | 09:00 PM
leolebo28's Avatar
Thats great advice sounds like some practice is definately necessary to get the feel of this. I guess one thing I should have mentioned is that its street night tomorrow, the tree is fully lit reds and yellows then straight to green(i guess like a street light) so I'm not sure if I should still follow this
Old May 11, 2006 | 09:04 PM
typeR's Avatar
all im saying is dont worry about the light just try to run the car as best possible and dont worry about cutting a light or the guy next to you
Old May 11, 2006 | 10:36 PM
leolebo28's Avatar
thnx for the advice
Old May 11, 2006 | 11:39 PM
MarbleGT's Avatar
'08 MX5 GT 6spd.
no you arent....liar
Old May 11, 2006 | 11:53 PM
CleanCL's Avatar
listen to typeR
Old May 12, 2006 | 02:02 PM
leolebo28's Avatar
not anymore i was still hoping last night that the damn meds would kick in.....was i wrong
Old May 12, 2006 | 04:57 PM
Joe5.0's Avatar
TQ > MPG
My handbrake is weak, so I just take it up to 3k and feather the clutch for a couple feet. This is on dr's tho, on stock tires you have have to pratice slipping it from abot 2k-2500rpm.
Old May 12, 2006 | 07:17 PM
power3dfx's Avatar
Parting out 02 Type S :(
typer, that is some good advice. though i havent launched with a manual fwd v6 honda yet (will soon!), preloading is the key with any fwd car. For example, with my sced auto, i achieved the best launches with tq braking (preloading).
The reason preloading helps is that when you release all power, the car has already lifted its nose and there is less of a nose hop when you finally launch. If i were to launch from idle, the nose would jump up instantly with lots of unwanted upward travel. This sudden shock produces the most pronounced jump in the front end, which is perfect for RWD launching but has the opposite effect on our FWD layout.
If you can get many runs in, try various techniques to see what fits you best. I think 4k is a bit high, but i havent launched a manual fwd before so...
Finally, try each technique 2-3 times before moving to the next (if you get 8+ runs). This way you will know which launch consistently netted a better 60 footer.
Goodluck and let us know the (hopefully good) results!
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
Acura604
Sep 28, 2015 12:24 PM
navtool.com
Sep 25, 2015 05:15 PM
