6 speeders: Is this normal?
Car has 18k on it and I just noticed this today. Depressing the clutch is fine, car shifts fine, letting out clutch is smooth except if I let out the clutch slowly, during the last little bit before the clutch is not depressed at all there is a small vibration. Kind of hard to explain but I can feel it in my foot and it's kind of annoying. I don't recall noticing this previously.
Any help is appreciated.
Sounds like a bit of chatter in the clutch. Have you smelt clutch before? If you heat scored the clutch it could have created a hard spot, and hence the vibration or chatter.
Nope, no clutch smell and with the winter weather around here, I've been driving it about as slow as possible. Today was the first time I've noticed it.
I've only had mine for about 3 weeks but it doesn't do that. It's got about 17K on it so the mileage is really close to yours ... I will say that this is one of the toughest clutches I've ever used. The few other people who have driven it stalled her in first. I've never done that but it's really hard to get a smooth transition into second (I usually get a little bump of speed). I'm working on that but I definitely don't feel a vibration. How hard do you drive your CL?
I'm not hard at all on the car. I live in an area with a ton of police so I really have to watch it. The issue however, isnt when shifting, my shifts are as smooth as they have always been. It's just the very end of letting the clutch out, past the engagement point has a very faint vibration. I really wish I could describe it better.
I dont have this problem and I have 41k on my 6 speed. Some retard I let drive my car was hitting about 5000rpm and didnt let off the clutch all the way, this was the only time I have ever smelled my clutch burning.
I do drive my car hard as well.
Spectacular Aroma About
Might just be feeling the throw out bearing spinning on the pressure plate. The "clutch damper" that Acura installs is actually there to prevent these vibrations from being felt.
Originally posted by DCLS
Should I be worried?
DCLS : I am glad you posted this because I have been experiencing the same thing for the last 1k miles or so. I have 11k now. When the clutch is being let out there is the "shudder" and then I have hit the clutch in again and rev it back up and then it comes out clean. Don't race it or anything hard on the car at all. Ive had Acura MT's for the last 10 years and this is not normal I'm thinking. Doesn't happen every time but seems to increase with the colder weather temps. Ive been hoping it was going to resolve itself.
lets hear from as many more 6 speeders as possible guys . Assuming it is a "high spot" or something of that nature can this be a warranty issue ??
Where is my super sauce?
Cannot say that I've noticed it either, but like ChadT as soon as my foot feels full clutch engagement, I'm releasing the pedal quickly (or at least more fast then slow).
When I first read the post I was thinking DCLS was describing a hydraulic valving problem at the end of pedal travel...could this be a hydraulic issue as opposed to a clutch mechanical issue? Associated with cold clutch fluid? Just a thought.
good points but to me it feels very mechanical. When it does happen it just feels like "somethings getting caught up on something" very technical, I know
like what was mentioned about the 'ridges' or high spots how does this happen and what can be done about it ??
Chad thats what I was thinking about today because even after the car has fully warmed up and the ambient temp. is below say 45 it does seem to not shift as well as it does at warmer temps.
6speedctrlfreak Yes I also notice when it's really cold the pedal release fairly slowly compered to when it's warm. On my drive home I tried to feel for a vibration. You can feel a vibration if you are pushing on the pedal with the clutch engaged. Seems normal to me. You really shouldn't have any pressure on the clutch pedal once it has grabbed.
I don't know guys. The temps were in the 50s today and on my drive home I still felt it. When you let the clutch out normally and then after it grabs let the rest out fast you don't feel anything. But if you let the clutch out normal to slower you get a (it's not a vibration) notchy-type feeling.
I shut the car off when I got home and tried to see if I could feel the notchiness when I let out the clutch and I couldnt. It felt completely smooth. Car on in neutral, let out the clutch, feel the notches.
Has anyone ever run the car by the dealer service area and asked for one of the techs to just check something out really quick or would it be better to make an appointment? I don't know if this issue is major or not, but it definitely just happened and it's annoying. I also don't think this is weather related since i don't recall feeling this when the temps were in the teens.
DCLS: When you say : "I shut the car off when I got home and tried to see if I could feel the notchiness when I let out the clutch and I couldnt. It felt completely smooth. Car on in neutral, let out the clutch, feel the notches" are you saying that just sitting still and the car in neutral you depress the clutch then release and you feel the notchiness/uneven feeling?? I have to try this tomorrow. Also did you get the car new ??
Yes. With the car off, I don't feel the notchiness when I let out the clutch. With the car on, just sitting still in neutral and I let out the clutch, I feel the notchiness.
No, I bought the car used Acura Certified about 3 months ago with 16k on the car. Ive put almost 3k on it.
I would just stop by the dealer without an appointment. I've done it with my Wrangler before and my dealer was happy to spend 5 minutes with me. I would assume an Acura dealer would be happy to do the same. I tried to get a ford dealer to look at something and the service writer acted like I was really putting him out. I would expect more from Acura ... this a good opportunity to test what level of service your dealer is willing to give you. I still drive across town to have my Jeep worked on by that same dealer.
Occasional Browser
i have a shudder too.. it started with the shift in between 1st to 2nd and now it sounds like my clutch is gonna fall apart starting at 1st but i think i need a clutch replacement because my clutch isn't grabbing so well starting off anyways. my dash is squeaking as if it's not following the body of the car and i have weird squeaking noises near the back window somewhere (these noticeable squeaks are annoying.) i drive my car hard all the time and now i need new brakes soon too. 13000+ miles on the car. i'm going to get these problems fixed very soon when i find the time to spare my car and when acura has an available loaner.
I'm a newbie cls 6speed (37k) owner and a rookie manual driver. Lets just say I did smell burning clutch off and on for the first few days. I got better after that though.
Anyway, I feel the exact faint vibration when just the weight of my foot is on the clutch pedal. When its all the way to the floor, the vibration goes away. Did smoking my clutch a few times cause this?
DCLS : I am glad you posted this because I have been experiencing the same thing for the last 1k miles or so. I have 11k now. When the clutch is being let out there is the "shudder" and then I have hit the clutch in again and rev it back up and then it comes out clean. Don't race it or anything hard on the car at all. Ive had Acura MT's for the last 10 years and this is not normal I'm thinking. Doesn't happen every time but seems to increase with the colder weather temps. Ive been hoping it was going to resolve itself. lets hear from as many more 6 speeders as possible guys . Assuming it is a "high spot" or something of that nature can this be a warranty issue ??
well 6spdctrlfreak..it cant be eny thing with the weather because i live in ny and i have a used 2003 cl-s ..6 speed too..and i dont have evny such problemss.. i have right now 32k miles...
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
