6-speed engine torque damper installed
#162
Lives in Boost
Originally Posted by m733l
it just feels a little too rough for me. it makes the car lose it's comfort. however, it is a good mod if you want to go to the track. just not an everyday mod imo.
#164
Originally Posted by CL-Future
Do you have enough rubber bushings in yours or is it just washers and nuts? I have one on each side of mine which I believe helps dampen some of the vibration.
#166
I'll put you in the wall
i did both and left a lot of posts a couple pages back. i like the ride better with both of them in. My front one came loose a little when it was by itself because there wasn't another one to counter it on the other side. I dont have any issues with both in. They will reduce wheelhop drastically and the ride is not bad at all. If you've ever had a lowered civic in your life then it will still feel like a luxury car IMO.
#172
COTM Coordinator
would anybody be willing to get measurements of the OE bracket for front and back for the dampers. I wanna do this for my swap, but you cant buy the OE brackets by themselves, you have to buy the OE damper and i guess it doesnt even come with the lower bracket.
So if someone would be super kind and get measurements of the brackets that would be great..... and also a pic of where they mount to on the lower side.... i know its a lot, but it would help alot too.
#174
COTM Coordinator
the measurements im asking for are the distances from the bend to the ends of the brackets.... and im assuming its steel, but could you get a thickness....
do you think i could get away with bolting the bottom brackets..... kinda like the engine and tranny mounts bolt down.....
thanks by the way
thanks by the way
#175
thanks by the way
thanks by the way
#176
COTM Coordinator
which existing holes..... case i looked and didnt see any. i cut some L angle today to get the bottom brackets. and for the top i have sme stainless steel strips, that im gonna bend and bolt to the stock location, but thats why i need measurements.....
Hey fsttyms can you take a pic of the threaded holes you used, so i can see if mine has it..... i looked but didnt see any holes.
#178
wow i noticed how i seemed to lose all that great traction i had from both of these so i took the front one out and took it apart. GROSS. i couldnt even recognize anything. I had to clean everything, but it looked like one of the red bushings was starting to deteriorate. I just flipped it around and put everything back together nice and tight, put my TB spacer in, removed my CDD and started banging around again...i still love these dampers!
#180
Originally Posted by dfvcl
So what would be the best choice to install first, if I have only one damper. rear or back one?
#182
Originally Posted by J32A26MT
I assume you mean front or back one...I would do the front first, although it really doesn't matter...but definitly both of them.
#184
Lives On BOOST
Originally Posted by distortedolskool
this really doesn't do much for wheel hop as compared to the mounts. i've had only the dampers and now i have both.
#185
Originally Posted by krisdlm
do you think the mounts are worth getting for a dd
#186
Get the mounts over these. These were around & the mounts were not at the time. Now the mounts are here, there's no need for these.
A 6mt CLS will not have the problems ruff is having. Those seem to be auto problems.
My car is a DD & I'd recommend the mounts. Yeah the ride is a little more rough & vibrations are a bit worse, but I've been in many cars that are WAY worse then this car.
#187
Lives On BOOST
#189
Quarantuning
So I've read through this thread twice, and haven't found a answer to my question. Someone else even asked but no answer. I've got them installed per distorted's diagram (thanks btw). There are no threads left underneath the two nuts under the bracket. I held the top nut on the damper and tightened the bolt down. If I try to turn just the bolt without holding anything the damper will just spin freely. Its rotating on the bottom right? I'm guessing this is normal. Everything seems fine, the bolt is fully threaded into the top of the damper. I really just need some conformation on this.
Btw... I bought these used and took them apart and tightened everything down before installing.
Also do you think I can adjust the stiffness with less threading of the bolt?
Thanks.
Thanks.
#193
Quarantuning
The top bolt is nice and tight, but I can spin the damper with my hand. It seems fine.
Is it me or did these help with off the line torque steer? Feels like it pulls a little straighter now when I let the clutch out hard. Wheelspin has been reduced, but is not completely gone.
#196
Originally Posted by dfv3.2CL-S
Another succesful NRG damper install. However I used one of the old bushing by cutting it into half to create sleeves. This will prevent the lower ball joint from sliding side to side on the lower bolt. Thanks for the info.
My front one has given me tons of problems. The bushings stripped inside and i had to take it apart and put it back together and i still dont trust it anymore. I am going to do the mounts soon. I would say even buy the front mount first instead of doing these. From what it sounds the 6 speed has bearable vibrations for a DD with the new mount kit. Innovative got them right this time. I was considering just buying the front and side mount and leaving my rear damper on to help.
#199
6speed
just a word of advice. went to the dealership today cause i was feeling some vibrations on hard acceleration. just installed my ksports so i thought that was the problem. turns out i have 2 broken motor mounts and my rear damper went mia. i only checked to see if the screws were tight the first few months of having them on but i started to stop after a while. so if you do have these installed make sure to check they are attached well periodically.
