6-speed comptech supercharger install
#43
Drinking Beer In
Originally Posted by CL FWD SPEED
I thought fuel pressure should be at 36-38psi during idle? on standard pulley
#45
Without a wideband O2 sensor and gauge or getting on a dyno it's not going to be possible to get the fuel pressure exactly perfect for your car. The numbers I have provided are the best guideline to get you up and running safely.
Since our fuel management for this kit is based solely on a rising rate FPR and high-flow pump I strongly recommend a electronic fuel pressure gauge which you can mount within the car.
#46
MP90 uninstalled
Well I looked at the Autometer gauges. I have the 4377 boost/vac gauge. It is the ultra lite series. I will get matching ultra lite gauges but I want to know which ones I need. I am trying to spend as little as possible. My options seem to be;
4375 air fuel
http://www.autometer.com/cat_gaugede...id=3083&sid=11
4378 wideband airfuel (why is the one above not wideband and what does that mean? Why do I need it and which is easiest?)
http://www.autometer.com/cat_gaugede...id=3604&sid=11
For the Fuel pressure
either the one allout posted above or autometer 4363 (will I be able to tune if it is under the hood?)
http://www.autometer.com/cat_gaugede...id=3121&sid=11
Is there a much cheaper way to do it right?
Thanks again guys.
4375 air fuel
Thanks again guys.
#50
I say skip the boost gauge and go with the wideband and the fuel pressure gauge.
It's a belt driven compressor. You can't over boost. And any belt slip is going to be felt and/or heard.
With this kit I would say monitoring fuel pressure is the #1 priority, then Air/Fuel, then finally boost.
#51
MP90 uninstalled
Guys, I know how to adjust the FPR I jsut didnt know what to set it to. Now I know how and with what. I already have the boost gauge. It came with the blower. It is a 2-1/16" Autometer Ultra lite so I intend on sticking with that. I will get the fuel pressure gauge. Do I have to have the one in the car? Cant I just monitor the Wideband O2 gauge and it will tell me if there is a prob with the fuel pressure? I guess I will just get both in cabin fuel and wideband that match. Im just pissed it will be so expensive. does anyone want to buy my old s-speed 1-2-3-4 transmission gears and syncros for $200. They cost $750 new and mine look good.
BoricuaTL
04-08-2016 01:08 PM
NBP_BALLER
09-23-2015 08:18 PM
2003, 6mt, acura, cls, clutch, comptech, comptechsupercharger, fuel, installation, instructions, kit, letting, maryland, mdx, mp90, pressure, static, supercharger, vibrates
