3Rd and 4th gear pressure switch replace?
Old 10-26-2011, 06:10 PM
99TLhot's Avatar
Smile 3Rd and 4th gear pressure switch replace?
Hi every one i wonder does any body replace the 3rd and 4th gear pressure switch on the 01-03 TL and 01-03 CL ? i seen a member that do on his 3G TL but i wonder if anyone does it on 2G TL and CL? if you what is the part number and does it made a diffrence?
Old 10-26-2011, 07:28 PM
Master of Mountain roads
ThomWV's Avatar
I've seen references to changing them, but I haven't seen anyone say their's has failed. here is a set of them on E-Bay, factory parts, the guy wants $102 plus four or five bucks for shipping.
http://www.ebay.com/itm/300598872995...#ht_500wt_1126
Old 10-26-2011, 07:59 PM
99TLhot's Avatar
dont know if i should spend a hundred buck ummmm? couple guy that did the change on there 3G Tl say it shift better after change them.... well ill decide what i should do after this week... thank for the Link by the way
Old 10-26-2011, 08:18 PM
ThomWV's Avatar
I had sort of the same question. I bought myself a spare transmission (5-AT) with the near certain knowledge that mine is going to blow sooner or later. While I was looking for one I ran across that listing. It was tempting. It wasn't a lot of money and I have a transmission sitting on a pallet - I could change the things in less than 2 minutes. But then I asked myself, "why?". I couldn't come up with a good answer.
Old 10-26-2011, 09:23 PM
lowrd on tein CS biatch
CL-S progression 01's Avatar
u can take off the pressure switches and just clean them up and ohm/continuity test them.
if they are within spec and clean then there's no point replacing.
odds are it's gunked up or crap is lodged in the aculumulator or something of that nature.
NighthawkBlue (07-24-2014)
Old 10-28-2011, 04:08 PM
Baller of Uni
CLassy02's Avatar
How difficult are these to replace? Mine was throwing a code with the 3rd switch being the issue.
Old 10-29-2011, 01:41 AM
aznboi2424's Avatar
Very easy. Turn the wheel all the way to the left and look behind the splash guard behind the wheel on the transmission. Kind of hard to show without a pic but I think there is a pic on the 3G TL thread where this came from.
Old 10-29-2011, 06:27 PM
AM To WDP In My Garage
acura_dipset_tl's Avatar
Here's the link to the 3G section. https://acurazine.com/forums/3g-tl-2004-2008-93/110-diy-guide-replacing-3rd-4th-gear-pressure-switch-3g-tl-2004-2006-a-729149/
CLassy02 (10-31-2011)
Old 10-30-2011, 09:42 PM
well if ur getting that code then definitely address it.
I can only hope that that'll fix u up bud. if so. don't play the lottery that week..
u've used up all ur luck :-)
Old 10-31-2011, 01:07 AM
Baller of Uni
CLassy02's Avatar
So how similar is that link to the CL's switches?
Old 10-31-2011, 07:38 PM
aznboi2424's Avatar
Very close. They share almost the same tranny housing so its in the same location. If you look closely on the tranny, there's a 3 and 4 where the clutch switches are so that you know which one is the right one.
NighthawkBlue (07-21-2014)
Old 10-31-2011, 11:49 PM
Baller of Uni
CLassy02's Avatar
Yeah I saw those. Thanks for the link.
Old 11-15-2011, 02:39 AM
99TLhot's Avatar
Well i decide to replace 3rd and 4th Switches and i noted right away my car does not slam from 3rd to 4th now so im really happy about it and i hope it stay like that for a while> Well i don't have any picture but if you don't know witch switch go where i can tell you that the 3rd gear pressure switch (Part# 28600-p7z-003) is cover by a plastic peace, and the 4th gear pressure switch (Part# 28600-p7w-003) is about 6 inches to the left. Oh yea i when to the honda dealer they going to charge me twenty dollar more per switch then the Inskip Acura Dealer.
Old 11-16-2011, 01:49 AM
cbiscut05's Avatar
The first time my tranny failed acura said it was the 3rd and 4th gear pressure switch's
Old 11-16-2011, 06:47 PM
aznboi2424's Avatar
I highly doubt those switches will make your tranny fail, members switch them out so that the shift quality is better.
Old 11-16-2011, 09:59 PM
YeuEmMaiMai's Avatar
switches fail because they get clogged from crap. cleaning them and reinstalling them will help it live longer. prolly should take them out once a year and clean them.
Old 11-17-2011, 11:36 PM
99TLhot's Avatar
i dont know but if the switches is bad then it make the car shift bad and that lead to tranny fail, that what i think, but ofcouse auto tranny go bad in time even if you not beat on it " alot". But try to change fluit and clean them switches out and it should last for a while,so far i replace the new switch and the car shifted better for now and see how long it going to last for me ......
Old 12-15-2011, 06:24 PM
99TLhot's Avatar
been replace the switch for about a month now and the car still shift pretty smooth ....
Old 12-17-2011, 07:01 PM
ChucksCL-S's Avatar
Rather than that I switched to all Redline ATF type F synthetic and a tranny cooler, so far so good.
Old 07-21-2014, 10:51 AM
NighthawkBlue's Avatar
Can we get a post of the specs?
Thanks again for the info on cleaning.
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
mike from annapolis
05-07-2017 08:21 PM
Skirmich
09-15-2015 06:41 PM
DS2000TL
09-09-2015 09:26 PM
HeloDown
09-08-2015 06:51 PM
Quick Reply: 3Rd and 4th gear pressure switch replace?
