3.5L Dyno
Old Jul 27, 2004 | 08:44 PM
typeR's Avatar
3.5L Dyno
just got back...in preperation for the uni chip ....
so
255.7/222.5 scans if someone ca host them my a/f fell of rapidly from 14.7 at 3400 down towards 13.75 to 4200 then dips again to 13.5 until 5K then it falls hard again to 12.7 only to bounce back up to 13.2 at around 6200 where it slowly dips below 13 until redline
Old Jul 27, 2004 | 09:01 PM
mattg's Avatar
send them to me
nice #'s btw.
Old Jul 27, 2004 | 09:14 PM
typeR's Avatar
Originally Posted by mattg
send them to me
nice #'s btw.
do you have IM...my email wont send big files
Old Jul 27, 2004 | 09:24 PM
mattg's Avatar
not at work i don't.
Old Jul 27, 2004 | 09:39 PM
Zapata's Avatar
Cost Drivers!!!!
typeR,
hit me up if you need..........
Old Jul 27, 2004 | 09:42 PM
typeR's Avatar
Originally Posted by Zapata
typeR,
what's your IM?
Old Jul 27, 2004 | 09:43 PM
typeR's Avatar
BTW i should add ...this was on a mustang dyno,but done in dynojet mode....and with the wheels on
Old Jul 27, 2004 | 10:23 PM
Chaptorial's Avatar
typeR do you still need a host?
Old Jul 27, 2004 | 10:31 PM
blader's Avatar
Audi S4 driver
yeah I can host
Old Jul 28, 2004 | 12:33 AM
darrinb's Avatar
///M POWER
great #'s
Old Jul 28, 2004 | 07:16 AM
scalbert's Avatar
Let me know if you need them put up.
BTW, very nice number, pretty much exactly where Doug's runs were at. The torque is also very impressive.
As I would have thought, the car is running a bit lean. You probably should be running right around the 13.0:1 range the entire run.
Old Jul 28, 2004 | 03:35 PM
mattg's Avatar
where is the freakin dyno?
Old Jul 28, 2004 | 03:36 PM
mrsteve's Avatar
Looks lean... I'd be scared to see what the UniChip will do to lean it out even more
Old Jul 28, 2004 | 03:44 PM
CleanCL's Avatar
very nice numbers, is that just purely the 3.5's power or any other mods on it?
14.7 is a bit high for my taste, but at least it drops right away.
Old Jul 28, 2004 | 03:46 PM
mrsteve's Avatar
^ Intake/Headers/Mugen Cooling mods/Crank Pulley/Lightweight wheels
Impressive numbers
Old Jul 28, 2004 | 03:48 PM
mattg's Avatar
i would be stoked if my n/a dyno looked like that.
TypeR would put bus lengths on most of us in n/a form.
Old Jul 28, 2004 | 03:49 PM
mrsteve's Avatar
~20 extra hp and ~20 lbs/ft more than me before pulleys.
Old Jul 28, 2004 | 03:57 PM
mrsteve's Avatar
After looking at my dyno, my A/F with the UniChip is about the same as yours is right now. It was very high 14s before 3500 RPM, then it settles in at 13.2-13.4... slight dip at 5700-6000 RPM down to 13.1 then back up to 13.6-13.8.
If the UniChip could lean you out more in VTEC to around 13.5 you'd probably pick up even more power. I'm assuming you are going to need a custom tune with the 3.5L?
Old Jul 28, 2004 | 04:26 PM
allmotor_2000's Avatar
On N NA car you need to run a tad lean to maximize horsepower gains... it won't damage anything.
Old Jul 28, 2004 | 05:09 PM
typeR's Avatar
home from work anyone wanna IM me and host these?
Old Jul 28, 2004 | 05:12 PM
Chaptorial's Avatar
Whats your im?
TypeR
Old Jul 28, 2004 | 06:46 PM
typeR's Avatar
Originally Posted by Chaptorial
Whats your im?
TypeR
type R on MSN ...doveyA at aol
Old Jul 28, 2004 | 07:04 PM
mrsteve's Avatar
mrsteve's Avatar
Your torque increase is amazing. My dyno showed peak torque of 201 around 2500-3000 rpm. After that it dropped off to around 185. You are at 210-220 throughout.
Old Jul 28, 2004 | 07:17 PM
ChadT's Avatar
Spectacular Aroma About
Wow that is a nice torque curve!!
Old Jul 28, 2004 | 07:30 PM
darrinb's Avatar
///M POWER
wow, thats a very flat trq curve
Old Jul 28, 2004 | 07:38 PM
Joe5.0's Avatar
TQ > MPG
Those are very nice numbers
Old Jul 28, 2004 | 07:47 PM
UDEngineer's Avatar
This Space for Rent.
That tourque is a thing of beauty
Old Jul 28, 2004 | 07:56 PM
Joe5.0's Avatar
TQ > MPG
The tq curve is nice, but thats really only 15-20lb ft more than stock. Its the hp that impresses me though. Any reason for the drop-off at 6k rpm? I woulda thought with all your mods it would continue to pull to 7k.
Old Jul 28, 2004 | 08:22 PM
EL_CLS's Avatar
Devil's Advocate Returns
IMO, longer stroke is running out of air... The air velocity/charging is pumped up through the midrange. The rod ratio is also changed.
The curve is pretty typical of strokers.
+ the intake air resonance charging reacts differently to the varied displacement of the 3.5L.
The other issue that shouldn't be neglected is the nice fat chunk of HP/TQ that is showing up at the "hefty" part of the 1/4 mile where the aero forces are really nasty at close to 90- to 100-MPH and the auto is in 3rd gear pulling "around" 5- to 6-k revs.
If there was ever an argument or compelling argument for "area under the curve,", IMO, this would be it...
Old Jul 28, 2004 | 08:26 PM
niz181's Avatar
how much does the 3.5L conversion cost?
BTW nice numbers
Old Jul 28, 2004 | 08:36 PM
mrsteve's Avatar
Not quite, peak torque may only be 15-20lb/ft more, but on my automatic J32 with similar mods to TypeR, my peak torque occured at 2500-3000 rpm and then dropped to around 185-190 throughout. I see this as a 30-35 lb/ft increase.
Old Jul 28, 2004 | 08:37 PM
Joe5.0's Avatar
TQ > MPG
Isnt his a 6 speed tho? A stock graph layed on top of his would be nice to see where the most gains are.
Old Jul 28, 2004 | 08:45 PM
mrsteve's Avatar
He has an '01 CL-S
Old Jul 28, 2004 | 08:47 PM
rezurex's Avatar
drop em like its hot
wow... how much did this cost? and what MDX parts did you take, and what are your other mods besides the conversion? very interested in what you did... nice numbers
Old Jul 28, 2004 | 08:48 PM
typeR's Avatar
who are you? doug?
Old Jul 28, 2004 | 09:22 PM
scalbert's Avatar
Nope, an '01 5AT. A 5AT normally only puts down about 180 lb/ft with headers. So that is a huge jump in torque.
scalbert's Avatar
Originally Posted by typeR
who are you? doug?
EricL
Whoops, did I blow the cover.
Old Jul 28, 2004 | 09:24 PM
scalbert's Avatar
This exact one was done by a person at a dealer in FL but he is no llnger openly making it available. The short block prepped was about $2500 not including the removal and reinstallation of the engine.
I suspect there were some other minor aspect which typeR could fill in.
Old Jul 28, 2004 | 09:42 PM
EL_CLS's Avatar
Originally Posted by scalbert
EricL
No, the book's cover "Neural Pathway Mapping with Tesla Coils and Cognitive Mapping with Microwave Ovens" has been unchanged (they haven't blown it up yet.)
Available Springer-Verlog (1st Edition avail 1st Qtr 2006)
"Comments made by EL_CLS do not necessarilly reflect the views of this station...."
