3.5L Conversion with 0.25OS 05RL Pistons Finally Complete
#41
Never had a clean run
Alright, opened it up last night just through the gears and didn't hold it for long just to be safe and yes it definitely is NOT at the top end of my estimate. But it could very well be at the bottom end of it. My guess is that with my mods, I gained about 40+HP. More of the power seems to reside in the low end torque. Low RPMs and even 4th gear pulls a lot harder. So I guess the HP numbers won't blow people away but the TQ should be a little more impressive.
#44
Originally Posted by av6ent
Sounds
So, what was the setup? Same as 02AV6?
RL pistons, Type S block, Odyssey or MDX internals?
#46
Originally Posted by All Mine
I can't wait to see to dee some dyno numbers. Ayougo got some nice stock numbers. What size turbo are you going with?
#47
hey just in case you didn't know, over bore does NOT change compression! By the way, what kind of downpipe do you have, or did you paint the Comptech one with that wierd gray color.
#51
Originally Posted by rtatsutani
Pretty much except for that of course the obvious one is he has an entirely different fuel management system (which is currently causing him WOT issues), he has a SC, mine has the 0.25 over bore and 0.25 oversized RL pistons and I also threw on my UR underdrive crank pulley and got it balanced with that on to create a smoother running engine (which he may have done?).
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
And he has NO WOT issues
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Curious how much you dyno NA
#52
13.68 @ 102.56
Originally Posted by typeR
im going on 2 years with this stock trannny
GTO 400/400.
Congrats rtatsutani on your conversion and....
for living in Hawaii...nice
#54
And where'd you see the pic of my comptech downpipe? Real life? Anyhow, it was cleaned I think using some kind of acid dip and sand blasting.
#55
I was asking about short block
. OK so, just .25 oversized pistons difference.
and running on stock crank pulley.
Curious how much you dyno NA![Wish](https://acurazine.com/forums/images/smilies/wish.gif)
And only 500 more mi. to go.
#56
So you mean to tell me that the overbore piston that you got from Acura for the 05 RL that was meant to take up slack in older motors or after machine work will raise the compression in an 05 RL? I dont think so! In any case factory pistons add the over bore just slightly below deck level to compensate for the extra material they added on the sides. So regaurdless of your over bore you DO NOT make higher compression than anyone else with 05 RL pistons. In any case all you did was take up the slack that you created when boring out the sleeves.
#58
#59
2600lb CL
What ever your last dyno run was NA, I'm going to assume you got around 10-15 more whp but a good amount of more torque, especially in the low end.
I'm predicting I'll only see around 250whp (i like to under estimate so I dont get my hopes up) with my J35 swap. The only advantage I would have would be the fact that I'm swapping in the 6spd tranny, therefore I should have slightly more hp coming to the wheels with the smaller percentage of drivetrain lose. My car has been in the shop for a good while though, because they've been busy with the SEMA cars.
Goodluck with your dyno...
#60
#61
Mistake again. A J series tranny will bolt up to a J series block. The only thing that may need to be modified would be the hole in your floor for the cables to go through. Just have to buy the linkage, shifter, cables, tranny, gauge cluster (so you dont have those stupid letters anymore. on top of that you get LSD. Just send the car back to WMR they'll hook it up!
#62
So you're saying it should be cheaper than the 3.5L swap??? I hope so
![Yum](https://acurazine.com/forums/images/smilies/yum.gif)
#63
I'm sorry but you are mistaken. The ECU is different as is the subframe, axles, motor mounts, exhaust manifolds, and pedal mounts (there are not holes to bolt up a clutch pedal) on the 6MT CL-S. It's a lot more than just bolting up the transmission and changing a few interior pieces.
#65
If this is the case, then no 6spd for me.
![Rant](https://acurazine.com/forums/images/smilies/rant.gif)
#67
#68
the axels are the same on the 6mt, the motor mounts arent that different the manifolds are the same,however inside the car i think things get tougher...
#69
I thought the axels were different. Hmmm. I know he would need different manifolds. His headers won't fit on the 6MT cars.
#70
Nuff said. Headers which i just chromed, intake if no spacer, mounts which I just bought, blah blah blah, gonna cost way too much. The guys at the shop said there's a place here in hawaii who does trans and TC mods. Gonna see what they can do for me and for what price. Nobody got any info on Dr. Evil? Anyone use him?
#71
#72
Originally Posted by peakpowermotoring
Honestly if you love spending this much money I would suggest you get a mid 90's japanese turbo vehicle and modify it. I would suggest a 3rd gen supra or 2nd gen MR2 for this task. Its very easy to get these things into the 12's and 11's with the money your putting in the CL. The CL is a great car but its no sports car, sorry to burst your bubble, I just feel your wasting your money dude. ![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
#73
#74
#75
Nothing wrong with being original and thinking outside of the box. It's not about just going fast like anyone can do with a supra, 240 or MR2, it all about originality and having the best of both worlds including a relatively rare luxury vehicle and decent performance. Isn't this why most of us are modding our cars? Most of the people in this forum know this car is a money pit but we still do it, just to our own abilities.
#76
#77
Sorry but eventually you'll get to the point where you spent more on the mods than you did on buying the car. Trust me I speak from experience. Good luck with your car dude. ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
#78
Very well put. Congratulations on the 3.5 swap. Lets see some dynos. Did you call BSM?
#79
1 Post
I got a dyno run with 4 baselines for $45. IT was advertised asa 3 but I wasnted to do at least one run in 2nd and at least 1 in 3rd, so he let me do 2 in each to verify continuity. WAs a cool guy, and I'll be going back there to tune all my stuff when I get it on
![Cry](https://acurazine.com/forums/images/smilies/cry.gif)
#80
13.68 @ 102.56
Haha, alright, I'll try to make sure I stop myself from sliding down that slipery hill.
If I had put the same amount $$$ in the GTO that I put in my TL I would have a 9-10 sec car.
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
