215 45 17 versus 215 50 17..
Old 01-14-2004, 12:13 PM
Eggplant-EX's Avatar
With the 215 45 17s, are they slightly larger tires or slightly smaller tires????
Old 01-14-2004, 12:14 PM
juniorbean's Avatar
Received 1,760 Likes on 1,046 Posts
Smaller... lower profile.
Old 01-14-2004, 01:01 PM
hemants's Avatar
215/45/17 are too small for a TL/CL
235/45/17 or 245/45/17 would be the right size
Old 01-14-2004, 01:13 PM
thanks!!
Dragging knees in
Pure Adrenaline's Avatar
Just in case you didn't know, here's a break-down of the tire size specs --
For example, if it's 215/50/17 ->
215mm wide tread, refering to the contact patch to the ground.
50 means 50% of the tread contact patch is the height of the sidewall.
17 refers to the size of the tire on the inner ring.
So the different between 215/50/17 and 215/45/17 would be that the latter has a thinner profile in relationship with the tread width.
Old 01-14-2004, 02:41 PM
///M POWER
darrinb's Avatar
215/45/17's will fit
Old 01-14-2004, 02:46 PM
mattg's Avatar
yes, but they are too short. throws the speedo off by 4%.
Old 01-14-2004, 06:40 PM
I want to make sure that I go slightly bigger. If I go smaller, then I am running up my speedo/warranty quicker....
Plus, I actually like the high stance.
235 45 17 worries a bit though as it seems awefully different from stocks
Old 01-15-2004, 07:01 AM
louisn's Avatar
http://www.miata.net/garage/tirecalc.html
This link will show speedo error if you change tires sizes.
Old 01-15-2004, 07:26 AM
hemants's Avatar
"235 45 17 worries a bit though as it seems awefully different from stocks"
235/45/17 is exactly the same diameter as stock. And if you have CLS wheels (7 inches wide) there's absolutely no problem.
P.S. a minor point but the first number isn't the contact patch, it's the sidewall width (and thus will differ depending on the width of the rim it is measured on)
Since we're on the topic:
215/50/17
Sidewall width = 215mm, div by 25.4 = 8.46 inches
Sidewall = 50% of 8.46 = 4.23
Overall diameter = 17 inches plus two sidewalls = 25.46 inches.
215/45/17 = 24.61 inches, almost an inch too small!!!!
+/- .3 inches in diameter is a non-issue, beyond that one has to wonder
Also one final point. Strictly speaking, the ideal diameter is 25.68 inches. This is what the original non type S was calibrated too and I doubt they recalibrated the speedo/odo for the type S.
Old 01-15-2004, 07:30 AM
RaleighNC's Avatar
How wide are the rims on the 04 TL? I read they're using 235/45 (I think in the new acura mag).
D-Rob
62
01-05-2016 11:44 AM
IIDXholic
10-08-2015 07:53 AM
nuldabz
09-03-2015 05:49 PM
gavriil
10-24-2003 05:36 AM
Quick Reply: 215 45 17 versus 215 50 17..
