2003 CL Engine Help!!!
Old Nov 26, 2014 | 08:12 AM
YoDaddy1323's Avatar
Dealer told me I may need a new engine soon! Anyone knows where I can find one??? Help Please!
Old Nov 26, 2014 | 08:44 AM
Scottyknows007's Avatar
What did they say was going out on yours?
Old Nov 26, 2014 | 09:04 AM
dealers like to throw out blanket statements.
you may not need a new engine.
what is wrong with yours?
Old Nov 26, 2014 | 09:31 AM
teh CL's Avatar
at this thread..
More info on the engine problem..
Old Nov 26, 2014 | 09:33 AM
Misfire codes 1-6 and P0172 - Bank 1 Fuel system too rich. A compression test was done and the compressions vary from 95 PSI to 160 PSI. Cylinder 1 has 80% leak down. They're guessing maybe water or an over rev caused some of this damage.
Old Nov 26, 2014 | 09:34 AM
Old Nov 26, 2014 | 09:41 AM
Cant over rev in an automatic.
are you 6MT?
Old Nov 26, 2014 | 09:48 AM
are you 6MT?
yup
Old Nov 26, 2014 | 09:50 AM
so, this next question is important.
did you over-rev?
or
did you suck up water?
Old Nov 26, 2014 | 09:55 AM
did you over-rev?
or
the only water i can think of maybe from the cold air intake but i have a hydro shield so i kind of doubt that. The over rev could have came from me letting someone drive my car smh but i'm not sure of the exact cause
Old Nov 26, 2014 | 10:34 AM
gnuts's Avatar
3.5 psi
did you have these codes when you took it in or did they test drive it and mess it up?
You could put in a J35A3 engine. Teh CL documented what's necessary to change over (it's not much) from your 6speed engine. It's plug and play and you'll have a 3.5. Put in your type S cams and you have a 3.5 type S. Check carpart.com
Old Nov 26, 2014 | 08:14 PM
thanks i didn't think about that
Aug 15, 2019 12:58 PM
drillzzz
Jul 28, 2019 06:30 PM
LECKEY73
Feb 22, 2016 01:32 PM
Aging-Hacker
Oct 5, 2015 11:44 AM
Sep 17, 2015 09:01 PM
