2001 CL-S Transmission questions
I have done the search on the forums ...
I got the following from Curry
(1) 37820-pge-a55 control module $980
(6) 08200-9008A Fluid $7x6 = $42
(1) 200cp-pgf-090rm $2,400
Do I have to change the control module?
Can I just change the control module or does the whole package have to be changed
I assume if the TCC solenoid is bad the trans is on the way out also.
Just get yourself a 07 accord v6 trans, swap over the range switch and solenoids (recommend replacing them with new or cleaning) and have a trans that will last
Which v6 one is the question?
A.T., Cpe (2 Dr), 3.0L (6 cyl)
A.T., Sdn (4 Dr), 3.0L (6 cyl), Hybrid
A.T., Sdn (4 Dr), 3.0L (6 cyl), non-Hybrid
I assume 4 dr non hybrid
BoricuaTL
04-08-2016 01:08 PM
