2001 Acura CL will start with starting fluid but won't stay running
Hi everyone, I have a 2001 CL that will start with starting fluid but the quickly stops and not stay running. I got help from my last post from this community on the knock sensor and where it was located. I found that the knock sensor wire was chewed away. I put in a new wire I purchased from the Acura dealer and was hoping that was the reason the car would not start. The car now will crank but not run, but if I spray starting fluid, it will start and run for a few seconds and then stop. I replaced the fuse/module under the dash for the fuel sensor, but made no difference, The fuel pump was replaced last year.
I'm not sure what to do next. I have a reader machine to read the codes but no specific code came up. It says ( Emissions Related Engine DTCs, No power train DTCs or Freeze frame data is presently stored in the vehicle's computer ). When I had to take the top of the engine / what the youtube video called "The Beehive" off and I also had to take out the front fuel injectors to get to the knock sensor to replace the chewed wire, I noticed the fuel injectors very dirty. Would the dirty fuel injectors keep the car from starting ?
I appreciate any help from the community.
Thank you,
Haroldredmond
Thank you,
Haroldredmond
I am dumb
Thank you,
Haroldredmond
Thank you,
Haroldredmond
Try a fuel pressure test using a gauge.
Does your fuel pump start when you turn the key to electronics? You should hear it for a second or two, then it'll cut off. I've had a fuel pump issues in the past. Had a brand new one fail on me within a month of use. Then another one a month later. It was a head ache.
clearly a lack of fuel. Rat chew more wires? Fuel fuses? Disconnect fuel line have some one turn on the key quickly to see if you're getting fuel in the engine bay. Cuts problems in half
Thefireball (10-27-2022)
Thefireball (11-03-2022)
I am dumb
Yeah, give it a check. It's a simple fix with a soldering iron. Just reflow the solder on the board, and it should work. Or grab one from another car & test it.
ThaiTL
01-25-2020 04:09 AM
Mark K. Wells
08-10-2013 01:56 PM
