2 problems, possibly related?
Old Jul 19, 2009 | 06:45 PM
Scepter's Avatar
1st: On the highway or crusing at a constant speed (during cruise control) on level ground the rpms will shoot up 500 and drop 2-300 randomly but nothing is affected by this. Possible electronics problem?
2nd: Driving down residential streets it feels like the VSA turns on but no lights turn on to show this. Like the feeling of accelerating but then the car stops it so you feel like "hopping" kinda would describe it.
Any ideas of causes and possible fixes for these? Much thanks guys!
Old Jul 19, 2009 | 07:35 PM
Rajca's Avatar
wham bam thank you ma'am
have u cleaned the iacv? seafoam?
Old Jul 19, 2009 | 08:31 PM
Scepter's Avatar
actually...no, no I haven't. maybe I should try that tomorrow and see what happens.
Old Jul 19, 2009 | 08:40 PM
Rajca's Avatar
that should help
Old Jul 19, 2009 | 11:05 PM
civicdrivr's Avatar
Does the idle fluctuate when stopped?
Old Jul 20, 2009 | 10:14 AM
Scepter's Avatar
no, the idle is fine when stopped or parked. Otherwise I was going to start checking for a vacuum leak.
Old Jul 20, 2009 | 10:56 AM
CL-S24's Avatar
I've been getting those same small revs when I'm on the freeway too. I can feel it slightly too, like a quarter of a rev up and down. any specifics on how to clean the iacv?
Old Jul 20, 2009 | 12:11 PM
civicdrivr's Avatar
Do it while the engine is cold. Remove the two coolant lines running into it, unplug the connector, unscrew the IACV. Use carb cleaner to clean all the ports and make sure the rotor can spin.
Old Jul 20, 2009 | 12:47 PM
1hotcls6's Avatar
spark plug misfire
Old Jul 20, 2009 | 02:31 PM
Pseudomaniac's Avatar
If you're auto, that's telltale sign of the torque converter letting go. If you stomp it to accelerate at 60, does it slip before it kicks down / after it kicks down ?
Old Jul 20, 2009 | 04:17 PM
1hotcls6's Avatar
look for flashin CEL. = misfire
Old Jul 20, 2009 | 04:40 PM
civicdrivr's Avatar
Nice catch. I didnt realize he was an auto until I reread it and saw VSA
Old Jul 22, 2009 | 08:07 PM
Scepter's Avatar
no slippage when I stomp on the gas. Just the usual half a second lag for auto trans you know...lol
Old Jul 22, 2009 | 08:36 PM
any kind of clunking when shifting into R from Park when cold ?
May just be something stupid like a loose vac line / leaking vac line.
Old Jul 22, 2009 | 10:09 PM
Scepter's Avatar
No weird clunking when shifting from R to D when the engines cold. I was just driving it this afternoon and it could be the engine mounts possibly? I had it in D, applied the brake and the whole front end lifted up pretty high when I goosed it a little...
Old Jul 23, 2009 | 04:45 AM
Rajca's Avatar
u need new engine mounts
Old Jul 23, 2009 | 05:20 AM
The stock struts are only good for about 100k of abuse too.....not sure about your idle surge though.
If the engine is racing higher in RPM while in motion, but the the vehicle isn't moving any faster - something between the flywheel and the tires isn't grabbing the power it's supposed to, or in the way it's supposed to.
Old Jul 24, 2009 | 10:57 AM
Scepter's Avatar
well this weekend Im going to be replacing the suspension, springs shocks struts and top mounts, (cracked Comptech Springs and broken endlinks) probably also replace the old 1st gen Comptech RSB on it (looks extremely rusty).
get the motor mounts replaced, probably get one of those torque dampner things and some other stuff.
Ill see what happens when its all done.
Old Jul 24, 2009 | 12:24 PM
djarovsky's Avatar
I vote for the torque converter as well. That is exactly how my second tranny went.
Have the Acura dealer take a look at it....it took them a little time to reproduce the issue on mine, but they did.
Old Jul 24, 2009 | 01:46 PM
The driveline isn't suspension components. The only reason suspension components would cause this is if you were bouncing the front wheels off the ground and losing traction, or if your camber was so out that your edges were losing traction under load.
DRIVELINE - THINK DRIVELINE!!!!
Feb 25, 2020 09:57 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
HeloDown
Sep 8, 2015 06:51 PM
jfman55
Sep 5, 2015 02:55 PM
