2 problems, possibly related?
1st: On the highway or crusing at a constant speed (during cruise control) on level ground the rpms will shoot up 500 and drop 2-300 randomly but nothing is affected by this. Possible electronics problem?
2nd: Driving down residential streets it feels like the VSA turns on but no lights turn on to show this. Like the feeling of accelerating but then the car stops it so you feel like "hopping" kinda would describe it.
Any ideas of causes and possible fixes for these? Much thanks guys!
Whats up with RDX owners?
Does the idle fluctuate when stopped?
Do it while the engine is cold. Remove the two coolant lines running into it, unplug the connector, unscrew the IACV. Use carb cleaner to clean all the ports and make sure the rotor can spin.
No weird clunking when shifting from R to D when the engines cold. I was just driving it this afternoon and it could be the engine mounts possibly? I had it in D, applied the brake and the whole front end lifted up pretty high when I goosed it a little...
The stock struts are only good for about 100k of abuse too.....not sure about your idle surge though.
If the engine is racing higher in RPM while in motion, but the the vehicle isn't moving any faster - something between the flywheel and the tires isn't grabbing the power it's supposed to, or in the way it's supposed to.
well this weekend Im going to be replacing the suspension, springs shocks struts and top mounts, (cracked Comptech Springs and broken endlinks) probably also replace the old 1st gen Comptech RSB on it (looks extremely rusty).
get the motor mounts replaced, probably get one of those torque dampner things and some other stuff.
Ill see what happens when its all done.
Have the Acura dealer take a look at it....it took them a little time to reproduce the issue on mine, but they did.
The driveline isn't suspension components. The only reason suspension components would cause this is if you were bouncing the front wheels off the ground and losing traction, or if your camber was so out that your edges were losing traction under load.
DRIVELINE - THINK DRIVELINE!!!!
HeloDown
09-08-2015 06:51 PM
