19x8 +45 Axis Seven Mods... RUB????
looking to buy a set of Axis Seven Mods +45 offset with 235/35/19 tires. i have a TLS /w HR Sports drop. if i cut the fender tab, would that be enough. would it only rub if ppl were in the back? if so than i dont really care about that. what part of the tire will rub and whats so bad about rubbing? tire damage? i oculd live /w a lil rubbin here and there i think. opinions please
Since you have a TL-s consider 225/35's if you want to be completely safe, but 235/35's could work if you trim the tab. I have 19x8 +49 with 225/35's and don't rub with it lower than H&R drop
Blown LS6!!
I have the same wheels and same springs and I still feel there is too much of a gap btwn the wheel and fender. I never even come close to rubbing. You'll be fine.
Blown LS6!!
I must note that I'm running 225 series, although the Parada's run a bit wide for a 225 (so I've read).
BTW, get those headers on the car ... or change your sig.
yea they are 235s Nittos. still thinkin whether i should pull the trigger and go for it.
yea the headers are sittin in my garage. no time to get them installed. have u been to the track /w ur setup. wonderin how much the 19s will affect acceleration.
Originally posted by GOT PSI?
You will still rub slightly with a full load or under a hard corner. Your setup is indentical to mine!
Blown LS6!!
I've never run the 1/4 in my car so I don't know if my car is actually slower. The 19" wheel+tire combo I have weighs the same as the stock wheels w/ SO3's. I'm sure the larger diameter wheels take off a few hundreths or so...it isn't noticable at all w/ the butt-dyno.
It's Go-Time.
how bad is rubbing? will it ruin the tire? also, did u cut the lil fender tab?
War Eagle!!!
Doin' da crack shuffle
Originally posted by momentum3.2
yeah so I google'd axis seven mods for shits & grins, this guy came up: no comment
![Hijack](https://acurazine.com/forums/images/smilies/hijack.gif)
Pure hotness. :phatyo:
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
