19 x7.5 42 offset
19 x7.5 42 offset
Does anyone know if a 19 x 7.5 with an offset of 42, will rub on an 03 type S lowere with comptech springs. And what size tires would you recomend ?
thanks
thanks
i have 18x7 w/ +42 offset, 225/40-18. i rub in the back a little bit. but my car is twice as low as a comptech drop. you may rub a little with passengers in the back going into steep driveways etc.
i think you would want to get 225/35-19.
PACDAT
I had 18x8 + 45 offset and 225/40/18 and NEUSPEED race drop (less than 1 finger gap) on My old CLS and NEVER rubbed.. not sure why u guys are??..
19x7.5 with +42offset and 225/35/19 rubber sounds like it SHOULD be ok?.. but i wouldnt recommend rolling on that thin of a sidewall.. its better for you to go 18s.. less headaches in the long run.
FYI: almost anything with a 42 offset is going to throw shit all over the side of your car... so if you like road tar and stone chips alot, then I recommend the 42 offset.
I wanted to get the Niche F- 16's but they only come in a 42 mm offset, and I don't want them to rub. After hearing all of these horror stories about 19's I might end up just settling for 18's so I can have a bigger side wall. Besides if I get 18's there is a much bigger selection!!
neuronbob
23
07-16-2019 10:48 AM
SinCityTLX
55
10-11-2015 01:20 AM
