15K Maintence...
Old Jul 18, 2005 | 02:00 PM
rcz22's Avatar
15K Maintence...
So i have 17K on my CLS, brought it into Acura for an oil change...guy said that i'm overdue for the 15K checkup, it'll be $325 with a loaner. After reading whats done, it doesn't sound like its worth all that much. He tried feeding me some line that if something goes wrong and my records indicate that I haven't kept the car in proper service condition then it'll be harder for them to do warrenty work....is this true?
is the 15K service worth it?
Old Jul 18, 2005 | 02:07 PM
DRM600's Avatar
i believe that it is not required that the dealer perform routine maintenence in order to honor warranty work. the guy was feeding you some shit to sell you an expensive service visit. look in your manual in the service schedule and iirc, the 15k service is really no more than an oil change, brake check and visual inspections.
Old Jul 18, 2005 | 02:18 PM
spdy0001's Avatar
I now drive an accord....
As long as you can prove you preformed an oil change at the scheduled times you will be fine. Those are "recommended" services, but not required.
Old Jul 19, 2005 | 08:20 AM
fuzzy02CLS's Avatar
I'd find another dealer, since that ones just cares about stealing your $$ & lieing to you. What he said is comlpete BS, & I'd file a complaint cause it's illegal.
Old Jul 19, 2005 | 11:02 AM
GreenMonster's Avatar
IIRC the 15K service is just an oil change and tire rotation ?? I paid $151 for mine, and I thought 150 was outrageous. I've since decided to do my own (I have a certified honda tech who will hook me up for stuff I can't do).
From the Acura's owner link... doesn't anyone read their manuals anymore
15,000 mi/24,000 km/1 yr Scheduled Maintenance
Recommended service for your 2003 Acura CL:
Replace engine oil.
Rotate tires (follow pattern on page 269 of your owner's manual.
Replace engine oil filter.
Inspect front and rear brakes.
Check parking brake adjustment.
Inspect tie rod ends, steering gear box and boots.
Inspect suspension components.
Inspect driveshaft boots.
Inspect brake hoses and lines (including ABS).
Check all fluid levels, condition of fluids, and check for leaks.
Inspect cooling system hoses and connections.
Inspect exhaust system.
Inspect fuel lines and connections.
jriv7
May 8, 2020 05:50 PM
oyayjoe
Jan 1, 2019 10:17 PM
gokhanturk
Sep 27, 2015 12:54 PM
ctlx23
Sep 13, 2015 09:55 AM
oyayjoe
Sep 12, 2015 04:40 PM
