12V Power socket question
Old 10-16-2006, 09:07 AM
fuzzy02CLS's Avatar
How much power can I suck from the 12V outlets with it being in a safe range? I have some things I need to power & the 12V sockets would work great instead of a switch.
They are not that high power, about 5 amps each, but having several things spliced into the same cables, so maybe 15-20 amps total on each outlet.
Old 10-17-2006, 12:42 AM
Blown is Best
Allout's Avatar
I don't think that those outlets are rated for that much power. You may be better off running another circuit directly off of the battery. Using an amp power kit would be a safe way to bring that type of power in.
10 gauge should be good for 15-20 amps
http://www.crutchfield.com/S-LVYne8u...=142PA10&g=711
Old 10-17-2006, 02:44 AM
YeuEmMaiMai's Avatar
10 amps max
Old 10-17-2006, 07:44 AM
fuzzy02CLS's Avatar
I did the math last night, I'll be just under 10 amps on each 12V outlet. I'm running the front outlets already & it seems fine. The console is next.
If I need it I'll buy something like this..
Old 10-17-2006, 10:11 PM
Blown is Best
Allout's Avatar
I would suspect that the console power outlet is on the same circuit. If this is correct, you will still be limited to 10 amps combined for both outlets.
Randy99CL
04-07-2016 06:00 AM
VA2000TL
10-02-2015 08:26 AM
ibGTV
09-28-2015 03:40 AM
09-17-2015 09:01 PM
datadr
09-12-2015 09:12 PM
Quick Reply: 12V Power socket question
