10K service
10K service
What have you guys had done around 10K service wise? The manual basically says just an oil change. I was going to go oil change, air filter (lots of crap in the air due to all of the fires out here) and have them check out the brakes - slight pulsating. Had tires rotated at 6K. Tranny flush can wait until 15K from what I've seen here...overall, car is running great. Any thoughts/suggestions? Thanks in advance
Administrator Alumnus
10K shouldn't be much more than an oil/oil filter change. Even the air filter should be good still, however that's a cheap part to change if you're inclined to do so.
The brakes should be looked at and problems should be fixed under warranty...
I only did the 15K service. But when I took it in, my brake pedals had the smallest of pulsing. When I brought it in, I just told them that I was feeling the brakes pulsate when I slow down from 50-60 and that I did not want my 15K service until they tell me what they will do about the brakes (did not mention TSB). They called me back 2 hrs later and said they got the authorisation for the brakes but did not want to do the brakes till I okayed the 15K service. LOL!! What was cool was that they said they turned the rotors and came in below spec, so they replaced everything. I highly doubt they turned the rotors and thing they were just sticking it to the warranty before replacing the rotors. The shimmy was very very minor but I wanted it fixed before the car had too many miles on it.
15K service was about $175 (total with tax).
