104,000 mile service . . .
Anything else I should look at?
CHANGE;
1. Engine oil and filter
2. Engine air filter
3. Cabin air filter
4. Spark plugs
5. Timing belt & tensioner
6. Water pump & radiator coolant
7. Transmission oil (drain/refill) DO NOT FLUSH
8. Accessory drive belt
CHECK;
1. Front & rear suspension (shocks, bushings & mounting points.)
2. PCV valve
3. EGR valve
Not going to deal with checking the valves. Idle is smooth with just a touch of ticking.
CHANGE;
3. Cabin air filter
4. Spark plugs
CHECK;
2. PCV valve
3. EGR valve
I would check your valves. you can hear loose valves but you dont hear tight ones.
I know im gonna be taking my intake manifold apart to clean the whole thing. its not too hard. but other then that, looks like you got everything.
Also a 3x3 drain and fill is better then just 1 drain and fill. thats what im gonna go. not damaging like a flush but you get like 90% of the fluid out.
plus what chuck said.
Private shop. $462.95 labor and $548.91 in parts.
Additional service of decarbonizing throttle body and a injection flush included in the above costs.
No, very slight valve ticking and a VERY smooth idle. Wrench has been doing Hondas/Acuras for 15+ years and said don't do it. He says tight valves will affect idle. If I chose wrong, it will just give me an excuse to get the GS350 I have been lusting after.
mada51589
05-03-2022 08:54 PM
Zonian22
11-14-2015 01:20 PM
asahrts
09-04-2015 05:55 PM
