03 CL windshield wiper issues
Old Jun 29, 2009 | 03:04 AM
3.2VtecTL's Avatar
Exclamation 03 CL windshield wiper issues
Problem: Windshield wipers continue to stay after I turn the switch back to the off position??
Any idea what could be the issue? I'm thinking a bad wiper switch??? I've been having to take the fuse in and out during the rain!
Thanks in advanced...
Old Jun 29, 2009 | 06:52 AM
Pseudomaniac's Avatar
If they're staying on even though they should be off (aka, the switch is off) then I would suspect the switch. Do your intermittent controls work (can you control the speed?)
Something is completing the circuit, and since when you pop the fuse, they're off - I's supect the stem switch contacts are failing or dirty...maybe disconnected?
Old Jun 29, 2009 | 08:40 AM
AnthraciteBeast's Avatar
^ x2 I'd say its the switch
Old Sep 17, 2009 | 12:51 PM
3.2VtecTL's Avatar
Arrow
Tried a known working switch and it did the exact same thing...
the intermittent controls don't work...it stays one speed for int & II
then III is fast, like it should be, and also when I pull down for mist its fast like it should be, however they will stick whenever they are positioned when i let go of the mist feature....
If I use the wiper fluid, they will stay on..at a slow speed...
It must be 1 of two possible solutions....Wiper Relay or wiper motor.....
anyone know where the wiper relay is located on a 2003 acura cl-s 6 speed?
csmeance
Jan 7, 2026 06:25 PM
TL-Rocket
Apr 29, 2023 02:33 AM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
iRaw
ILX
Sep 18, 2015 12:44 PM
rockyboy
Sep 17, 2015 02:37 PM
