03 Acura Cl Type-S seafoam
^^Don't tell the n00b to search. You've been here long enough you should have pulled up a link.
here's a seafoam DIY
https://acurazine.com/forums/showpos...52#post2033721
And welcome to the club. Don't forget to check out the FAQ forum when you get a chance.
Well I didn't mean it in a harsh way.
I first answered his question and in case that wasn't satisfactory...where to find more info.
But the question was a simple yes or no question.
Next time I'll try to be more helpful.
Damn I never would have thought to use the vacume line like that. I just poured the whole damn thing in the gas tank like it said on the bottle. I'll have to go get some more and try that out.
right now im at 58,000 but i was just wondering because i did it to my last car which was a 94 acura legend GS at first i felt a slight difference but it went away within the week
I did it yesterday. There a DIY on the 2nd gen TL side. Cleans out carbon deposits in the engine. You also put some in your gas tank for the injectors. Basically it loosens up the gunk and it's burnt off and comes out your exhaust....most people have lots of black smoke.
I didn't have any smoke, but i have low miles. After doing everything the idle was sooo smoothe you couldn't tell the car was even on.
its the name of the product. i assume the name comes from the smoke it releases when cleaning your engine internals....... i dont think it should smoke if you only put it in the gas tank...... if you put it in the crank case and through the intake it should smoke... if you do all three at once, it will smoke but it will only be from the crank case and the intake.....
If you put it in your crankcase and it smoked you have a serious problem with your motor. It should only smoke if you run it through the intake. Maybe a little if you put alot in the fuel. But should not smoke in the crankcase.
When I did it to my CLS with 65K miles, it did not smoke as much as I thought it would. But it did run super smooth afterwards. When I get home next week, Im going to do it to the wifes 05 Pacifica. We got it with 11k miles and were at 42K or so now. I'm betting it is going to smoke like crazy. I was also thinking about switching from Mobil 1/ Valvoline Syn to Royal Purple. (I've only used Moble1or Valvoline syn, just depended on wich was on sale)
Once you get a can make sure to read the directions. I think they are more in depth on thier web site. Things like making sure the engine is good and hot before you put it through the intake is important.
You won't be disapointed.
seafoam
Just did this to my 03 cls. I am actually going to do it again because the mechanic that did the 105k service before I purchased the car, installed the plenum gasket backwards and I was scooping carbon out with a damn spoon! This did however help me get the car for super cheap and the dealer was pissed for letting it go for so low and when I told him how easy it was to fix the misfire issue.
The instructions on the back of the can states "For use in all motor oils including synthetic. Can be used before or after oil change."
sockr1
10-01-2015 01:31 AM
