'01 E brake help ...
Old Aug 23, 2004 | 05:02 PM
typeR's Avatar
how do i adjust it? ...just had a friend turn the rotors and new pads and...the e brake is still loose though it was before the job ...never been adj. as far as i know...anyway the pedal has more travel also ...i was thinking the line needs to be bleed he thinks it's how much of my rotor they had to cut and that now the brake has to travel furthur?>>>>>>
Old Aug 23, 2004 | 05:08 PM
mattg's Avatar
there is a little adjuster down by the e-brake pedal
Old Aug 23, 2004 | 05:18 PM
typeR's Avatar
sweet ...what do you think about the brake travel...and i should add...if i pum it a few times it feels normal...im thinking bleed/fluid level?
Old Aug 23, 2004 | 06:55 PM
4pumpedCL's Avatar
Honkey
You probably need to bleed the brakes. Start at Rear Right, then Left Rear, then front right, then front left. As far as the ebrake goes, you can also adjust the ebrake at the rotors. If you take the wheel off there's a little rubber grommet. Remove that and it gives you access to the brake adjustment. Use a flat head screw driver to tighten or loosen.
-Aaron
Old Aug 24, 2004 | 10:56 PM
typeR's Avatar
need more help see the adjuster i think but what do i turn?
Old Aug 26, 2004 | 10:16 AM
typeR's Avatar
MrHeeltoe
20
Feb 23, 2023 01:54 PM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
