'01 CL-P vs. Pontiac G6 Coupe
Not a doctor
1 Post
Coming home from the mall on 17N in Jersey about 9:30 i was pretty happy there was little to no traffic. I was cruising about 70 in the left lane when from behind me came a black G6 coupe. He stayed behind me for about thirty seconds then switched lanes and gunned it past me then eased back into the left lane in front of me to cut me off.
My younger brother said to me: "Dude Ryan you just got owned by that guy in the Pontiac, you're not gonna let it slide, are you?"
I was in a sporting mood, so i went to the middle lane and pulled alongside him, still cruising about 70-75. We toyed around with each other for a bit, one pulling a little bit and then settling back until i downshifted to 3rd and pulled a solid 3 carlengths in front at about 95.
By then we hit a wave of cars approaching Allendale, so we chilled a little bit until we passed through the swarm. We came to a nice two mile stretch of highway with little traffic, so we lined up even at 65, me on the left, him in the center lane.
He launched first, and i gave him a legit 2.5 car lead, when i downshifted back into 3rd, rode it through vtec through up to about 5000rpm in 4th at 115 and put a huge gap between us which he wasn't able to close.
We both resumed regular speeds as we approached the more commercial area of 17 then we both went our separate ways.
Iono about that 3 length car pull between you two cause I believe the G6 Coupe has the same exact motor and chassis as the v6 Solara and these cars can give us a run too. Even with the AEM Intake it wouldn't make that be of a difference. Anyways nice kill
Moderator Alumnus
![Post](https://acurazine.com/forums/images/icons/icon1.gif)
Specs for 2006 G6 GTP
Specifications
Type: Midsize Coupe
Where Built: United States
Dimensions
Exterior
Length: 189.1 in. Width: 70.4 in.
Height: 56.4 in. Wheel Base: 112.3 in.
Curb Weight: 3525 lbs.
Interior
Front Head Room: 38.9 in. Front Hip Room: 52.6 in.
Front Shoulder Room: 54.2 in. Rear Head Room: 36.3 in.
Rear Shoulder Room: 51.1 in. Rear Hip Room: 49.9 in.
Front Leg Room: 42.2 in. Rear Leg Room: 35.8 in.
Luggage Capacity: 14 cu. ft. Maximum Cargo Capacity: 14 cu. ft.
Maximum Seating: 4
Performance Data
Performance
Base Number of Cylinders: 6 Base Engine Size: 3.9 liters
Base Engine Type: V6 Horsepower: 240 hp
Max Horsepower: 6000 rpm Torque: 241 ft-lbs.
Max Torque: 2800 rpm Maximum Towing Capacity: 1000 lbs.
Drive Type: FWD Turning Circle: 39.3 ft.
Specs for 2001-2003 CL-P
Specifications
Type: Midsize Coupe
Dimensions
Exterior
Length: 192 in. Width: 70.6 in.
Height: 55.5 in. Wheel Base: 106.9 in.
Ground Clearance: 6.2 in. Curb Weight: 3470 lbs.
Interior
Front Head Room: 37.5 in. Front Hip Room: 52.9 in.
Front Shoulder Room: 56.4 in. Rear Head Room: 36.7 in.
Rear Shoulder Room: 54.2 in. Rear Hip Room: 50.4 in.
Front Leg Room: 42.4 in. Rear Leg Room: 33 in.
Luggage Capacity: 13.6 cu. ft. Maximum Seating: 4
Performance Data
Performance
Base Number of Cylinders: 6 Base Engine Size: 3.2 liters
Base Engine Type: V6 Horsepower: 225 hp
Max Horsepower: 5600 rpm Torque: 217 ft-lbs.
Max Torque: 4700 rpm Drive Type: FWD
Turning Circle: 37.4 ft.
-The new GTP G6 will give you a run for your money with the CL-P. When the older G6's came out.......
2005 G6 specs from Edmunds.com
Base Engine Size: 3.5 liters
Base Engine Type: V6 Horsepower: 200 hp
Max Horsepower: 5600 rpm Torque: 220 ft-lbs.
-They didn't have much for a 3.5 liter...even for the GT model.
really? i didnt know the g6 had the same chassis and engine as the v6 solora. which year solara? and which engine? the new 3.9 one? im confused. please clarify
Not a doctor
1 Post
The Solara comes in two different engine types:
2.4-liter DOHC
16-valve VVT-i 4-cylinder
155 hp @ 6000 rpm
158 lb.-ft. @ 4000 rpm
3.3-liter DOHC
24-valve VVT-i V6
210 hp @ 5600 rpm
220 lb.-ft. @ 3600 rpm
i think it must have been an '05.
either way it felt pretty nice lol
and
to the white font!
2.4-liter DOHC
155 hp @ 6000 rpm
3.3-liter DOHC
24-valve VVT-i V6
210 hp @ 5600 rpm
Originally Posted by GreenMachine
You had to of killed an '05. ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
![Ninja](https://acurazine.com/forums/images/smilies/ninja.gif)
HOLLA! for the Type-Pee's =)
and
american = junk
G6 = :ghey:
except of course for the lovley cadillac XLR drop top that looks like a bullet out of an AK45
solara = G6 WTF ??? solara is the only thing on the road that looks like our cars, too bad they are for people over 75 .. . .
G6 = :ghey:
In the Mid-South meow
Nice kill, Green! Much luv 4 da CL-Peeeeeeee!
Moderator Alumnus
I don't have a lot of people wanting to race me for some reason. I dunno what it is. But it helps save gas though.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Haha, when I think CL-Pee, I usually think of yours Green, that's why I said that.
It's been kind of dry here lately, too. Hopefully after the New Year is over and done with and less po-po around more people will want to run it. I had a Jetta GLI mess'n with me the other day but we were only able to go two gears and he got a monster ricer fly by on me but I was pulln on him. Oh well.
Got DEP???
I rented a car in Waikiki, Hawaii last August and they gave me a G6 and the thing seemed to be power less... Had the typical GM traits to me...
I don't know, but I believe it was an '05
Not a doctor
1 Post
and idk what it is either, no one in jersey seems to be in the mood for a good race either.
i've been a little hesitant too though, because its that time of the year that all the drunk drivers start coming out of the woodwork and all the cops are on high-alert.
Once i get my radar detector for Christmas I'll be eager to get back out there though lol
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Moderator Alumnus
I agree. Once this month is over and the weather gets better and the cars are more cleaned up...I can almost guarantee there will be more kiddies wanting to race.
What do you mean when the weather gets better??? LOL, it's actually been kinda cold in AZ the past week or so. It's only gotten in the high 50's low 60's during the day. Freezn!
Actually, since drunk drivers was brought up, I witnessed a sick accident last week. I was coming home from my friends 30th b-day party and was sitting at a light waiting to turn left. Directly across from me on the other side of the intersection was a Lincoln Town Car waiting to take a left at his light. Out of no where, a second after the turn light turned green, a Seabring came out of no where like a bat out of hell and full speed (est. around 65mph) slammed into the back of the Town Car. It was by far the hardest impact I've ever witnessed besides a pickup flipping over one time on the highway. Anyway, I put the CL in park, threw on the blinkers, ran out and and called 911. As I was on the cell the girl driving the Seabring snapped out of it, pulled her head up from the airbag and started mumbling that she needed to get out of there and leave. Too bad her car was totalled and her drivers side door was pinned shut. Turns out she was extremely intoxicated and totally failed the field sobriety test. Thankfully the guy in the Lincoln walked out of it and seemed to be in decent condition considering the impact he just experienced. The back of the Town Car was completley accordianed along with the front of the Sebring. It was just the craziest thing to see and in the back of my head I was thinking if the Town Car wasn't there to stop that Sebring it could've easily been my car broad sided going through the intersection. Anyway, just a little illustration of what massive amounts of alcohol will do to your ability to drive. I hope everyone is really careful out there this time of year and just try to keep away from drunk drivers. Sorry to be a Debby Downer!
Moderator Alumnus
Oh...we wash cars when it's below 40 degrees, well, at least I do. I've seen plenty of clean cars in the past couple of weeks even though the weather has been kinda on and off.
I've been seeing accidents left and right. It's scary just to be in one.
Put an extra pair of panties on (LOL)...50-60...that's warm for us!
The strips will be open in spring time. I can't wait for that.
Not a doctor
1 Post
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
I wish it would just snow already. I wanna go snowboarding and try taking a shot of my Taffeta White with a snowy background
Merry almost Christmas guys
