Are 01-03 type s heads the best we got ?
Old Nov 9, 2009 | 10:46 AM
richardparker's Avatar
3.7L Nitrous Breathing CL
Are their any beter flowing heads than the type s heads ?
Any heads offer higher lift, longer duration cams, or make higher compression?
looking to get schooled on some head knowledge that out Anything perform beter than 01-03 type s heads ?
Old Nov 9, 2009 | 08:49 PM
Rajca's Avatar
wham bam thank you ma'am
07-08 tl type s heads, but those arent a direct bolt on. oil passages are diff or something like that.
Old Nov 9, 2009 | 09:11 PM
^Anyone that you know using them?
I looked at some but, either the intake side or the exhaust side had one big square hole,and I did'nt think it will line with anything.
Old Nov 9, 2009 | 09:15 PM
Rajca's Avatar
exhaust hole. the exhaust manifold is cast into the head. keep the type s heads and port and polish them
Old Nov 9, 2009 | 11:09 PM
YeuEmMaiMai's Avatar
04+tl engines are slightly shorter so the heads will not fit our blocks. Someone tried to use the CL-S cams on a 03 accord and they were about 1/4" too long. Interestingly enough the 09+ intake fits.....
Old Nov 10, 2009 | 07:55 AM
civicdrivr's Avatar
Yup, the second gen Js are slightly shorter.
You can use the 07-08 Type S cams if you make a spacer, but Im not sure of the gains, if any.
The CL-S heads would be the best you can get.
Old Nov 10, 2009 | 09:42 AM
Thanks for everyone's input. looks like I need to be searching for a cl-s top end to play with.
I thought one of the year mdx's had the same heads as the type-s.
drone619
Jan 26, 2016 07:09 PM
Lucrativesoldier
Sep 28, 2015 03:47 PM
braveheart
Sep 25, 2015 08:20 AM
Slow98teg
Sep 24, 2015 07:54 PM
