0-100 Times Ran Tonight
Temp was 94 degrees. Only problem is I'm up at someone's house in Scottsdale, so I had only one road to work with. Problem was from start to finish this road was about 20 Ft downhill over the couple thousand feet it takes to run to 100. Well anyhow my Cl-P ran 0-100 on this downhill in 16.55 secs. Now what does the CL-S run 0-100 stock and what does the CL-P run 0-100. (I have ran one other 0-100 which I posted at 17.80 flat road, is this time closer to stock it was 90 degrees and half tank when I did this one last week.) I also want to know how much this 20ft of gradual downhill effects it. Like not specfic just is it like .5 seconds or more like 2-3 seconds. I can tell it was 20ft cause where I started I was level with the Stop lights that were at the end.
[ 07-18-2001: Message edited by: pgatour1 ]
Originally posted by pgatour1:
<STRONG>Temp was 94 degrees, half tank. Only problem is I'm up at someone's house in Scottsdale, so I had only one road to work with. Problem was from start to finish this road was about 20 Ft downhill over the couple thousand feet it takes to run to 100. Well anyhow my Cl-P ran 0-100 on this downhill in 16.55 secs. Now what does the CL-S run 0-100 stock and what does the CL-P run 0-100. (I have ran one other 0-100 which I posted at 17.80 flat road, is this time closer to stock it was 90 degrees and half tank when I did this one last week.) I also want to know how much this 20ft of gradual downhill effects it. Like not specfic just is it like .5 seconds or more like 2-3 seconds. I can tell it was 20ft cause where I started I was level with the Stop lights that were at the end.</STRONG>
I have the CLS time up to 0..80 from the MT issue (it is still out from math city)...
0..60 --> 6.4
0..70 --> 8.1 60-70 1.7 sec
0..80 --> 10.5 70-80 2.4 sec
1/4 mile 14.8 @ 96.5 MPH.
80 to about 95 about 4 sec
If a bit of guessing was tossed in, perhaps these guys would have hit 100 in about 15.7 ???
0..60 --> 6.4
RLX-Sport Hybrid
3G RLX (2013+)
43
12-16-2015 10:45 PM
Abe_Froman
09-16-2015 01:27 PM
