View Poll Results: What kind of problems have you had with your XS headers?
Multiple Choice Poll. Voters: 135. You may not vote on this poll
*** XS Power Header Owner Thread ***
#41
In the Mid-South meow
#43
^^ Like the other thread you're posting in, it could be your IMRC. Do a search and you'll find infinite amount of info on it and what it does. It's a pretty common part to go bad and need replacing. Bad IMRC = No VTEC engagement.
#46
Missing my
Originally Posted by MADMAN187
can bolts of the same size and heat resistant be purchased at a hardware store..?
#47
ok so i just got mine installed today took 8 hrs and parts and labor = ~$450. Had a lot of problems a pipe wasnt level so i had to get it machined leveled. just really sucked but the mechanic said that it was well worth it because for that price each part individually is about 40-50 dollars separately. but the crappy worksmanship is a problem. he used the xs power gaskets and i dont know why but they seemed fine compared to the oem ones these are thick as fck. i love the sound i burned half a tank of gas trying to redline. very nice deeeeeeep tone. if i only had a cai in it would be even sicker. but even though i ran into all the install problems and labor costs imstill happy
#48
Midnight Star CL-S
#49
#50
Originally Posted by UNeeKLiNG
just got these installed last week...
From about 2500-2750 rpm from gears 1-4 it gets louder and i can hear some vibration coming from where the headers connect to the cat and when in 5th and 6th gear...the same vibration turns into some rattling in the same area...anyone have this problem at all? I'm thinking it's just the rubber mount that is used to hook in the j pipe of the header because i had a hard time screwing that part back on... thoughts? i hope that made sense...
#51
Originally Posted by Oakroadsteve
I got heat resistant bolts at Home Depot. I made sure that one of the associates familiar with that kind of hardware give me a hand. They were dramatically better than the ones that came with the headers.
#52
So does anyone remember the exact bolt/nut sizes and quanity? I used the shatty hardware that came with the headers and now I want to go back in and replace them with better heat treated hardware, but I have no idea the size/thread/quanity. Any help would be appreciated.
#53
Originally Posted by fsttyms1
I got grade 8 M10x30 10x40 will work as well. The pitch doesnt matter as long as you get the same pitch nuts to go with them
#54
Lives in Boost
Originally Posted by CLSixspeed
I would love to hear some more info from people that have tried this...
I'll be purchasing header wrap and putting it over the flex pipe as this is where i'm pretty sure the hissing sound is coming from. It's pretty annoying and noticeable when I get on the gas regardless of the gear I'm in and is most apparent from 2000-3000 rpm's. I'll let you all know how it turns out.
Other than that, the XS headers are great. The jet hot coating I got looks great and the smoothness of the power gain is honestly addictive...
#55
Midnight Star CL-S
#56
The hissing is my only complaint right now.. Sounds like my old chipped 1.8T A4 spooling up, which is not too enjoyable on a non-turbo car. I tried to listen where it was coming from, but couldn't make the noise without the engine under a load.
#57
Lives in Boost
#59
CL-Pride
Quick question, does the factory bolt and nut work on the XS header? I figure that everyone who upgraded his header gets new bolts and nuts as well.
#61
The OE manifold has 3 studs per side for the A-pipe, no bolts. The XS headers just have a flange with 3 10mm diameter bolt holes and they supply you with 8mm diameter nuts.
The main reason to get new bolts and nuts is to get the RIGHT SIZE. 10mmx30mm or 10mmx40mm not stronger grade 8 heat treated 8mm bolts and nuts that are TOO SMALL. The 10mm bolts will help you line up the flanges and keep the gasket on the sealing surface. That's why some have no leaking with the 8mm bolts, they were able to line up the flanges up properly.
Had my XS headers for 11 months and no leaks, cracks, resonance, or any other problems. Fit was perfect. I did have to clean up some of the holes and the flanges weren't perfectly flat but it was easily fixed.
#62
B A N N E D
how did you solve the issue with the flanges not being exactly flat? and what is the correct size of bolts that should be replaced 10mm or 8mm?
thanks Eric
thanks Eric
#63
I figured out one of my problems. The XS headers are such a tight fight that I needed to remove the hanger that holds on the XS headers next to the cat. That took care of the vibrations through each gear around 2500 rpm. Do you guys think that will cause any issues? It's not hanging that much lower without the hanger so I'm thinking it'll be ok. The last issue that I still haven't figred out yet is the rattling that happens aroudn 2500 rpm ONLY in 5th and 6th gear. I hear it towards the back behind the driver seat. Sounds like my exhaust but I wouldn't know why it would be. Thoughts?
#64
SOLD: 03 SSM CLS Auto
#65
Cool, thanks man. So I'd need 6 of them total, right? 3 for each header to A-Pipe connection? Also is that mm's? So it'd be 10mm x 30mm or 10mm x 40mm?
#66
#67
It is going to put extra stress on the welds and cause a premature failure at some point.. I would put it back or find another place to brace it.
#68
i am so smart S M R T
That's exactly what it sounds like!! Like a turbo spooling up but because you know you don't have a turbo it's annoying. I just ordered Silver exhaust wrap as well as high temp aluminum adhesive tape online. I'm going to tape where I suspect the leak is coming from (flex pipe) first and then put the silver wrap on. I should have more info on the results next week.
#70
agree. Just go to a muffler shop and have them relocate the hanger so that it fits properly
#71
OG 3.x^7 rawr
Installed the headers yesterday. Went very smoothly except the torch had to come out. Everything bolted up pretty good. No whinning sound just a little bit of a turbo spooling up sound at around 2000-3000rpm. I noticed one thing though, there is sound differance when it hits 3000rpms. It's like a deeper exhuast sound. The butt dyno did feels some more power but still waiting for the fullest after break-in. Good $125 spent!
#72
Lives in Boost
Originally Posted by 01clsstock
so.... what are the results?
The hissing sound is barely noticeable now
If you have any other questions I'll be happy to answer them but it won't be until later since I'm going to the track in about 5 hours, gotta get some sleep now...
Brian
#74
Lives in Boost
Originally Posted by Kulrevon
thank you so much for doing this.
Do you think the flex pipe is just crappy. Should I have another one installed before installing the headers?
#75
2014 TL SH-AWD Advance
I got my XS headers a couple weeks ago but they're still in the box. Waiting for some spare time to install them. I read something about insulating tape used on the headers and that it may drastically reduce the life of the headers. I'll see if I can find the link.
#77
i have xs power headers on my 97 3.0 fit is shitty, rubs on crossmember, leaks at both joints of the u pipe to headers... overall id say they really arent worth it, now i will have to find some dc sports or comptech...
#78
Lives in Boost
Originally Posted by LIPPSTUH
so it's coming from the flex pipe? did you clean the downpipe before you put the wrap on? maybe it just stuck to all the dirt and stuff.. try cleaning again.
#79
1 Post
So you spend about 75 bucks on top of the 115. and you have a perfect set.
I will do that before I spend the money on the comptech.
