$195...
15K mile service? What is that? ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Just do an oil change & rotate your tires & you'll be fine. Dealer services are a waste of $$ & are just dealer profit. Only 2 are important 60K miles & 100K miles. Both of which would be ALOT cheaper at somewhere other then the dealer. IMHO
Wow. Thanks. I feel better now. I thought I was taking it in the shorts for paying $151 for the 15K service (but they did replace the windsheild wiper blades).
You could get you tires rotated for under $40 bucks at a local tire place, and a $25 oil change at the quickie lube.
OR do it your self, and save about a $180. I've got my 22.5K coming up and I think it'll be done in my driveway.
I now drive an accord....
Wow I recently got quoted $109 for the 15K service and wasn't sure about that price. And it includes all kinds of good stuff that isn't included in the regular schedule.
Houses Won't Depreciate?
Just a recap
15,000 mi
Replace engine oil.
Rotate tires (follow pattern on page 269 of your owner's manual.
Replace engine oil filter.
Inspect front and rear brakes.
Check parking brake adjustment.
Inspect tie rod ends, steering gear box and boots.
Inspect suspension components.
Inspect driveshaft boots.
Inspect brake hoses and lines (including ABS).
Check all fluid levels, condition of fluids, and check for leaks.
Inspect cooling system hoses and connections.
#Inspect exhaust system.
#Inspect fuel lines and connections.
# = See information on maintenance and emissions warranty, last column, page 223 of your owner's manual.
15,000 mi
Replace engine oil.
I already changed the wiper blades, so I guess I will need just the oil change. Tire rotation and balancing is $16 @ Costco.
The parking brake adjustment will be done under warranty?
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
