Will these fit on TSX?
Axis Seven mod
Bolt Pattern: 5x100, 5x114.3
Offset: +35
I was aiming for 19 but if it will be hard for me to fit this then I guess i will have to go for 18. Thanks in advance. Does anybody have 19 on their tsx? Any advice?
Offset: +35
Photography Nerd
Offset is too low. Stock is +55 so try not to go any lower than +45.
There are lots of people running 19's and even a few running 20's. Check out the wheel gallery stickied at the top of this section.
thanks how about
bolt pattern: 5x100, 5x114.3
Offset: +42
Will these fit alright?
I'm a noob, can you tell me what "offset means" and will 18inch with 42 will be good for my stock suspention TSX???
Offset: +42
Photography Nerd
That should work fine. There are a number of members running that size. Go with 235/40/18 tires to complete the package.
Here's a good link to explain offset: http://www.tirerack.com/wheels/tech/...jsp?techid=101
Originally Posted by laee3
Axis Seven mod
Offset: +35
Offset: +35
The offset has nothing to do with the diameter of the rim.
It does have a relationship with the width of the wheel though.
Stock is 7" 55 offset. The lower the offset number, the more the wheel will protrude away from the car. Go too low and it will stick out past the fender. Also, as the wheel gets wider, some of that extra width will stick out too. So, your first example, 8" 35 offset will stick out .5" due to the extra width, plus another 20mm because of the offset, for a total of about 1.25". And that would be true whether it was a 17", 18" or 19" rim.
If you got a rim like the RonJon for example, you'd be looking at 19" x 7.5, 50 offset, which would be perfect-only 1/2" more than stock, so it would be well within the fender of the car......
hahah thanks guys, I love axis mod wheels, i guess if i can't go with 19 since its offset off, then i will go with 18, i just have ONE more question, will 18inch with 42+ fit into my "stock" suspension setting? or do i need to adjust it to get these rims fitted???
Just dial 1911
1 Post
Photography Nerd
Photography Nerd
yeah i'm just buying rims for now as well, i'm putting them up with a-spec suspension, so 19 won't be fitted??? there is no way???? i guess 18 is big enough... =/!!
Photography Nerd
how about ride quality??? when you choose to go with bigger rims
acura_dipset_tl
01-01-2016 03:02 PM
