Wicked Rear Camber Kit
Old 08-14-2010, 09:18 PM
knguyen553's Avatar
ACURA TSX 2003-2008 WICKED REAR CAMBER KIT 2004 2007: eBay Motors (item 400143792514 end time Sep-11-10 12:06:37 PDT)
Has anyone ever used this?
And is this all i need to lower my car? Because I lowered it yesterday and i forgot to get camber kits and now my wheels are cambered and the tires are dying.
Old 08-15-2010, 10:43 AM
AKACL9's Avatar
Good camber kit worth the money and yes thats all you need to stop your tires from dying.
Old 08-17-2010, 01:00 PM
PhiDelt's Avatar
I have the wicked camber kit, no problems at all .
Old 08-17-2010, 05:05 PM
Old Guy
Simba91102's Avatar
The Ingalls kit may be more money, but it also gives you the ability to adjust the toe (more adjustment that the factory arm). It's actually out of spec toe that wears your tires anyway, not camber. And.... it's easier to install (you don't have to break open the ball joint like you do for the Wicked arm).
Old 08-17-2010, 07:51 PM
xaznperswaesonx's Avatar
yea i normally stay away anything that replaces stock ball joints. if they break .. stock ball joiints are cheaper to replace than aftermarket kits.
hence why i haven't installed front camber kit. I got the spc ones in the rear. way easy to install.
Old 08-18-2010, 07:59 PM
I win
GianJ30a's Avatar
I have wicked on mine, havent had any problems so far
Old 09-08-2010, 02:44 AM
TSX x2
maiku's Avatar
Loving mine!!! Install was a breeze...
Old 09-08-2010, 07:40 PM
Midnight Garage
Mr Laocean's Avatar
Eh not really. Get toe adjusted and you're good.
Old 10-07-2010, 10:13 PM
Ck98vteC's Avatar
I have been dropped since spring and tires are evenly worn, no camber kit or abnormal wear.
Old 10-15-2010, 01:40 PM
lovemeruff's Avatar
using the wicked rear camber kit myself, i prefer wicked over ingalls or sbc.. im sure the wicked can go past my current settings.. -5.6 degrees in the rear. lololol
oyayjoe
01-01-2019 10:17 PM
james357
02-13-2016 02:37 PM
o8 ENVII 8o
11-30-2015 04:23 PM
09-04-2015 08:03 AM
nuldabz
09-03-2015 05:49 PM
Quick Reply: Wicked Rear Camber Kit
