Wheel Spacers with Built-In studs, please advise.
Old 12-22-2005, 02:47 PM
Got Milk???
kaikai114's Avatar
I'm looking to put 5mm-10mm wheel spacers to my car for the looks and it's for daily driving, no track. The spacers I found have "built-in" studs on them, and 5 separate holes to bolt onto the wheel hub itself. Has anybody heard of this before and is it reliable compared with the regular spacers? I'm guessing it might more even more stress on the suspension components than the regular spacers, but correct me if i'm wrong, any advice is appreciated
KC
Old 12-22-2005, 07:49 PM
My bolonga has a 1st name
97AcuraCL's Avatar
Can you clear out your PM box so that I can ask you where the camber kit I paid for is?
Old 12-23-2005, 12:17 AM
Got Milk???
kaikai114's Avatar
97AcuraCL,
Your PM box is full, not my, you will need to clear yours to be able to send/receive msgs.
I have a msg for you and the camber is on the way.
KC
Old 12-23-2005, 08:19 AM
97AcuraCL's Avatar
Originally Posted by kaikai114
97AcuraCL,
KC
cleared and thanks; i've been waiting but i'll now just get it installed over the break/new years
Old 12-23-2005, 12:21 PM
Got Milk???
kaikai114's Avatar
pm sent
Does anybody have any advices on this above issue with wheel spacers???
Old 12-23-2005, 12:53 PM
Yohan
curik_euro's Avatar
I had a similar situation. But, unfortunately there are no spacers with built in studs for thickness less than 25mm. Regular 5 mm spacers will be fine as I had this setup on the rear before. But 10mm, I strongly dont recommend them as there are no grooves left for the wheels to hang on. I replaced all studs with longer ones to accomodate these.
Old 12-24-2005, 03:17 AM
Got Milk???
kaikai114's Avatar
i'm gonna try 5mm all around and see how the car looks. after installing Ingalls camber kit in the back, the control arms pulls the wheel hub a lot inward, so now the wheels are inboard a lot more than when I had SPC camber kit.
KC
Old 12-25-2005, 12:53 AM
Buddyclub-CL9
BuddyClub-TSX's Avatar
KC
when you are buying the wheels for your car, get the RIGHT OFFSET. You wont need the wheels spacer.
Old 12-25-2005, 12:58 AM
Apex Clipper
Canyonball's Avatar
+1
I'd steer clear of ANY spacers.
Old 12-25-2005, 02:28 AM
JTso's Avatar
KC
Did you also get an alignment done with the Ingalls camber kit? If so, what were the specs? I'm suspecting the specs are off.
obert
11-14-2015 09:59 PM
DUECE_DXJ
09-24-2015 04:54 PM
yvr_tsx
09-15-2015 01:14 PM
jmoney2001
09-11-2015 12:07 PM
mtl_ilx
09-03-2015 09:48 AM
Quick Reply: Wheel Spacers with Built-In studs, please advise.
