What the best tires for 18/7.5 offset 42
FTW! I just purchased some Works CR Kai 18/ 7.5 with +42 offset. I wanted a nice look I already droped it with H&R springs .. What size tires would make it look the best...???
H&R drop is minimal I think so there is still quite a bit of gap I presume
Regardless, I'd go 215/40 on a 7.5... if you're slammed, 205. A 225 would be more 'standard' but IMO it loosk too beefy on a 7.5 |
What do you mean it's to beefy!?!?
Also what Can I get so the tres wont look beefy!
Originally Posted by wong05tsx
(Post 13093928)
Do 225/45 or 40. They'll be fine. I had 225/40 18 on my Volks SE37a's that were 18x7.5 +40 offset. Stock tsx rims are 17x7 so .5 more rim width can and will def be able to handle 10mm wider tires.
So what would be the best size? Going today to buy tires
I recommend 225/40/R18 as well.
^ditto
What im running right now on 18x7.5 +42 Work vs-xx |
225/40/18 would be best IMO
You could also do 215/45 but 225/40 is the most common for a 7.5" rim - that's Acura's recommendation as well.
225 on 7.5 is not beefy. So you could go with:
225/40R18 225/45R18 215/45R18 With 225/45R18 speedo reads exactly as GPS and the gap between the fender and the tire would be the smallest. Here's the pic of how it looks with 225/45R18 with Eibach prokit springs: http://farm5.static.flickr.com/4129/...87d60d1a_z.jpg also lower profile tire = more pressure to your suspension parts |
