Various Suspension Setup Info and Pics
#83
Originally Posted by free2d
Does anyone change shock to stiffen the suspension without changing the spring?
I feel that my car height is ok but just a bit soft. Trying to reduce the nose dive.
If you used the Neuspeed version of the Koni, you could go down a 1/4"; I wouldn't go 1/2" on stock springs though......
#84
Originally Posted by dzuy
what the hell? please tell me you didn't poke a hole in your seat to put that thing to adjust your teins?
#88
Originally Posted by virtualbong
#89
Originally Posted by SirTodd
I have the same car with the lip spoiler like yours, but will be dropping it and adding wheels very soon. Now that I've seen your car, I think I'm gonna have to get the kit. Thanks for the photos. They were a lot of help!
#91
e.
#92
Originally Posted by BlackTSXer
1. Buddy Club Racing Spec Coilovers.. no camber kit yet
2. I love these coilovers, ride is not harsh at all on softest setting.. but once you stiffen the ride it gets bumpy but i love it
3. 1300 or so from street image in baldwin park california.
I'm not sure how many inches i dropped it.. but ill eventually need to raise it once i get rims and oem kit..
front corner shot:
rear camber shot:
rear corner shot:
front corner shot:
rear camber shot:
rear corner shot:
#94
Originally Posted by feelgood13
Why is the top of the back wheel look pushed in? is that an illusion or do people do that on purpose?
Camber kits typically sell in $ 140-180 range ($70 a side x 2) and take roughly half and hour to install (per side) if you know what you are doing and are properly equipped. i.e. this is what a garage should charge. Once the kit is installed it is critical to have an alignment done, as the suspension geometry will be way out.
After you have your camber kit installed you can really enjoy the vastly improved handling of your TSX without burning a wear strip off on your rear tires. Let’s face it, they are not cheap!
#96
I am new to the forum and after reading many posts about the Tein Basic setup I think I will be making a purchase soon. Before I do I would like to take a ride first, anybody in the Phoenix,Az area have these and would not mind giving a test ride?
#99
Originally Posted by JakeD
so would a 2" drop work well on a 19" wheel with low profile tires?
#104
Originally Posted by polytsx
If you install a lowering kit, for every 1” you drop the height, the rear suspension will develop what is called camber, in the case of “dropping” the height the camber is “Negative”. The result of negative camber is largely that you will seriously accelerate uneven wear on your rear tires. Fortunately this can be easily and cheaply corrected by purchasing a camber kit.
#106
Originally Posted by anthongy817
Wrong. Negative camber does not affect premature tire wear. The toe is what causes major uneven tire wear. Zero out your toe and you will not have any problems with bad tire wear.
#109
Originally Posted by bighead411
anyone have any comment like TeinS/H spring
or Tanabe DF/NF 210
i'm sure there is some cheap ppl have low budget like me.
or Tanabe DF/NF 210
I've seen the springs go anywhere from $140 to almost $200 but i'm sure you can find a good deal like i did.
#112
Comptech swaybar
Anyone wants a Comptech Swaybar for TSX? Selling it for $100. I couldn't make mine to work with EVO exhaust. you can email me at sbudianto@yahoo.com.
#113
does removing [installing coilovers] the stock rear suspension require emptying out the trunk?
got this in the trnk right now it would take me a while to get it out :\
drflyboy30 (01-22-2012)
#115
Tanabe DF210 drop
Here are some picks of my retired TSX on Tanabe DF210 springs with stock shocks. I think someone was looking for pics?
I have a new 2008 PWP TSX so these same exact springs are going into that car as well.
#116
#118
Originally Posted by SimpleWhite
finalstage how long have had the tanabe springs installed with the stock shocks?
#119
Originally Posted by finalstageauto
Don't know if someone answered your question yet but no, you do not need to remove anything in your trunk. The top of the rear suspension can be found by removing the side pieces to your rear seats. 1 bolt removes each side of the seat pieces.
Thanks, i forgot that I even posted on this thread. Got the coilovers in for about 2 weeks now, I love em, I think I just found the sweet spot on the dampner settings too. There's some pix and a short feedback found in my thread
https://acurazine.com/forums/showthr...8&page=1&pp=25
and for those who are lazy to click; cliffs:
Buddy Club racing spec coilovers
~2.5-3" drop
dampner settings (from soft to stiff)
front - 6/15
rear 7/15
Absolutely love the drop, the car's itching for a lip kit now and some wheels, though. The ride is smoother, but i bumps are more profound.
a few pix; there's more in the link
stock rear below:
dropped rear below:
fronts:
sameoldmacho (06-21-2013)
#120
That is a very nice drop. Ah, the joys of coilovers. I myself have had coilovers in the past, but I just find that I end up being too lazy to ever adjust them again after I install them and lower them to the height I want. haha.
I know the drop on my old black car might be a little hard to see because of the black so I will repost pics again of my new PWP TSX after I get those springs re-installed. I'll do a before lip kit and after lip kit pictures so you can also see the difference.
