V (speed) & XL rating, important?
05' TSX comes preloaded with Michelin MXM4 P215/50R17/XL 93V
There are some good tires, same size (P215/50R17), but without XL rating, or rated H (one speed rating lower than V).
Are they fine? Or should I skip them?
- Felkin ZIEX ZE-915: 215/50R17 91V (no XL)
- Kumo Ecsta LX Platinum KU27 215/50R17 91W (no XL)
Someone stole "My Garage"
Going without the XL is fine as long as you are sure to maintain your tire pressures at or slightly above the recommended PSI. Try 34F/32R.
I'd be careful of combining that with a lower speed rating, as the speed rating is basically a heat-tolerance rating, and with more load on an SL tire (than an XL), + higher speeds, there's a greater chance for a blowout on a tire rated standard load AND a speed rating below V.
For handling and safety purposes I'd try as best as possible to stick with a V-rated tire, preferrably XL. That being said, I run General Exclaim UHP's in standard load, but they're ZR speed rated. No problems to speak of. I think they now come in a 215/50-ZR17, XL. Check them out, they're great 3-season tires.
joflewbyu2
10-08-2015 11:16 AM
ripit
09-26-2015 06:19 PM
