Urgent! - Tein Basic Information needed
Ok so Im looking into getting a set of used tein basics, I just dont know what else I would need that it doesnt come with. The only thing included is what is in the pictures. Can someone tell me what else I need, and where or If I can buy them?
Will anyone lend me parts if I dont need to have them on with the basics?
The tools to do the job if you're doing it on your own. A ball joint separator is the only specialized tool that comes to mind.
You're looking at the complete strut assemblies, so if that it's all you want to replace, your good.
k but I wont be doing the install on my own, im having a shop do it
so all of this is there besides hooks and manual...?
Contents of damper kit Height Adjustable shock absorber x4, Main spring x4 Lower spring seat x4, Seat lock x4, Thrust washer x4 Bump rubber x4, Dust cover x4 Hook spanner x2, Instruction manual
yes, they are already put together and the person was nice enough to include the top hats. when they come new, you have to assemble them yourself and use your stock top hats.
even if you have a shop install these, you will still need to get the wrenches if you want to lower or raise the car yourself. otherwise you will have to go back to that shop every time you want to adjust the height. the instruction manual goes through how to adjust the height.
yes, they are already put together and the person was nice enough to include the top hats. when they come new, you have to assemble them yourself and use your stock top hats. you should probably get the wrenches first so the shop can set it to the height that you want before they put them on the car.
Joseph Stansbury
34
Dec 4, 2015 01:57 PM
