TL rims on TSX
TL rims on TSX
Has anyone put Tl stock rims 17x8 on a TSX 17x7.5 with any problems. The acura dealership said that the tires will rub and discount tire says they won't work. If anyone has can you post pictures. I have a 2005 TSX. Thanks for any reply.
I ran those for awhile (with 235/45x17 tires, which is the OE TL size and same diameter as the OE TSX 215/50x17). I'm lowered about an inch, and I did occasionally rub in back which is why I gave them up. I've read varying opinions on the chance of rubbing; not sure if all had actually run the wheels. I'd say if you're stock height, you'll do fine. If you're lowered, you might be taking a chance. It could depend on what size tire you use.
