Tires for a 2004 TSX
Overlord
www.tirerack.com
Good site, shows ratings etc. I kind of like the way the Yokohama AVID V4S
looks for the performance and the price.
C'mon, man! Row yer own.
I've been extremely happy with my Avon M550's but have only had them for about 600 miles and not seen any snow or rain yet. Check them out in the ultra-high-perf all season section of TireRack.com.
send me a link to JDM??
Originally Posted by CGTSX2004
I've heard nothing but good things about these tires.
Originally Posted by moda_way
Put 1k on them and write about them. Seeing any difference in mileage? You've got me thinking about putting those on my summer wheels.
I'll put about another 1,000 miles on and then report on ride/handling/noise/mileage, but so far I love them.
To those of you with the Avons:
Do you have the A/S version? And, have you experienced any flatspotting problems as mentioned in some of the reviews on Tirerack.com?
Avon M550 aging
Anyone out there have more than a few thousand miles/Kms on their set of Avon M550's and if so how have they aged and what's your opinion now v. when you first got them???
I'm curious as to how they perform, sound, ride, etc. after 10k miles+. Any thoughts or comments?
I have about 1000 miles on the Avon M550's. I selected at the suggestion of Tire Rack. I like the tires, but they do flat spot after sitting over night. This feels like a bump on the tire for about five miles then it goes away. But was very concerning the first morning I drove the car. They handle well in all weather, and are quite after they warm up etc.
Try the Tires section search as well, but I too would say Yoko V4S.
My other "car" is a 4x4
I put a set of 235/45-17 Bridgestone Potenza RE750's on my '04 a few months ago. They handle great (much better than the stock tires) and I hope will last a long time. Even though they perform very well in wet weather, they are a "performance" tire.
Their only downside is that they're directional, and nearly all my high-speed cornering is towards the right, so the outside shoulder of both left tires is scrubbed a lot more than the right-side tires, and I can't cross-rotate them!
Something doesn't sound right. Did you have the same problem with the OEM tires? What other wear problems or anomalies did you have before you switched and after you switched?
Originally Posted by TSX.Fury
I had some issues with flat spotting when it was really cold out, but I mean really cold... like 0 degrees. But other then that I haven't had problems since it warmed up above 20.
Because so many of the freeway intersections/offramps where I live are right-hand cloverleaf-style ramps, my next set of tires definitely will NOT be directional!
Yes, the OEM tires scrubbed in the same way, but at least I was able to cross-rotate them left-to-right to even out the differences in tire wear between sides.
One main reason I'm thinking of switching out my OEM's for the Avons is tire noise. Are the Avon's significantly quieter? I can't believe how noisey the Michelins are. It seems like 80% of the noise at highway speed comes from the tires.
Effin' WERD!!
I just got back from my first semi-long road trip with the TSX. One highway we were on for an extended period of time had every imaginable surface, new/old asphalt, rough/smooth concrete and it just blew my mind the amount of noise translated through those tires. Some were tolerable (new asphalt) others were downright fatiguing (rough concrete).
I feel like it's such a waste to have to have such a nice, tight interior with minimal engine noise and excellent aerodynamics that limits wind noise all to be ruined by some crappy tires.
Hence I'm considering swapping them out even though I only have 2000 miles on them. Do they have any value to anyone? Do tire stores buy lightly used tires?
Originally Posted by FiVa
I absolutely agree! The tire kind of ruin the comfort of the car. Anyone know if the Yoko Avid V4S are quieter than stock? These seems like the most bang for the buck tires.
Originally Posted by green_henry
Yes, the Avids are quiter. They're great tires.
BTW, with my butt-gyroscope on-ramp tire-traction testing, the OEM's, while predictable, would let go pretty easily at around 55mph. I've gotten to 65mph on the Avons so far with no squealing and certainly no sliding. I will continue to summon the courage to go faster until they break loose and (hopefully) straighten out my line with a little lift-throttle. Wow, tires really do make a difference! The Avons are also TERRIFIC in the rain, as I found out today taking the same on-ramp. They can handle about the same speed in the rain as the OEM's on dry! I mean, wow!
Take the tire into consideration without the wheel for a second. Both tires in the front are rotating the same direction right? So they can be cross rotated it's just a PITA.
I haven't calculated mileage yet, wanted to get them broken in. I run them 4 psi higher than the Michelins (they're not XL load-rated, so the sidewalls are not as stiff); that might result in a little better mileage.
thanks
I think i just found my new tires.
Originally Posted by Alin10123
Put 1000 miles on them yet? Can you report back to us? If you had to do the purchase again... would you buy these for sure? Or any other tire?
thanks
thanks
Would I buy them again? Unquestionably -- I think they'll last me a while, and I can only hope the secret doesn't get out and they're not $175 next time I need tires. Their Tire Rack ratings are spot on, these would be terrific at $175. At $107, there's just no drawback to them if you're in the market for ultra-performance all-season tires.
I've been getting about 25 mpg on them (combined city/hwy driving), about 1-2 mpg better than the Michelins. Get 'em, you'll love 'em.
I have about 1500 miles on my Avon 550's and I can report that, having been broken in, they are nothing short of fantastic! Super traction in wet conditions, glued-to-the-road on dry pavement (I haven't found their limits yet on my favorite on-ramps, but I'm WAY beyond the OEM tires' top speed), excellent response in everyday driving, and they're quieter and smoother than the Michelins. They handle higher speeds flawlessly (they seem to really love 90-100mph), and snow traction is very good (although it's been so warm, we've had very little snow).
Quick question too... What's the difference between the Yoko Avid H4's and V4's? THe description for them is identical. Yet the H4's rank lower on the consumer thing than the V4's. Whys that? I'm asking because the V4's dont come in 18 inch sizes while the H4 does.
