View Poll Results: Which tire would you buy?
Voters: 33. You may not vote on this poll
Tire Suggestions?
Tire Suggestions?
I already posted a poll about this a month ago and still haven't bought new tires. I've been waiting for a local shop to be able to order Bridgestone Turanza's but they said they are backordered. So at this point I'm not sure if I want to order from tirerack.com or get a different tire. I've also changed which tires I am considering so I am posting a new poll.
By the way, I'm looking for the best all around all season tire.
I like the bridgestones because they are rated #2 by consumer reports, #1 by tirerack, and received the most votes in my last poll.
I am now considering the Falken Ziex ZE-512 because it was recommend by a local shop, it is rated #1 by consumer reports, and is rated well on 1010tires.com
I am also considering BFGoodrich Traction T/A because CY from tirerack.com recommended them and they received good ratings on 1010tires and tirerack. But their comfort and noise ratings are the lowest of the three.
I just want the safest, best handling, and longest lasting tire. But I've concluded no such tire exists.
Originally Posted by briny319
...best handling, and longest lasting tire.
If you want long lasting, decent performance tires, i suggest you look at the Yoko Avid V4S.
It has a treadwear rating of 500, which is quite impressive. Also, i heard it is fairly quiet, giving you a much more comfortable ride compare to stock.
I'm planning to get a set of these after my stock goes bald
A tread wear rating of 500 means nothing, which is the problem with the UTQG system. There is no standard to calculate from one brand to another. Brand A may have a 500 tread wear rating and offer a 60k mile waranty and Brand B will have the same tread wear rating and offer a 40k mile waranty. Then more importantly look at the company and dealer backing it up. NEVER and I do mean NEVER buy a tire based on its UTQG rating- one brand that is horrible about this is Hankook 850 tread wear tires traction A temp. A and poor performers all around, and wear out in 30k miles.
None of the above. I've used these on each of my TSXs:
Yoko Avid V4S
Yoko ES100
Read the reviews. I'd take either one all over again.
Yoko Avid V4S
Yoko ES100
Hmmm....$149 for a grand-touring all-season tire (the bridgestone) that has a 40k treadlife warranty, or $101 for a high perforance all-season tire (the yoko) that has a 60k treadlife warranty. I think I'd spend less and get the better performing tire!!
My problem with a lot of statements about tires on forums and at tirerack, et al. Is that most if not all the people replying have little if any real experience with other products. Sure the ES100 will outperform the stock michelin's but what name brand tire won't?
Tireguy,
My post wasn't talking about the ES100, but rather the Avid V4S tires. I realize that Yoko's 60k treadlife warranty is unrealistic, but I would be surprised if they wear out substantianlly quicker than the bridgestones (if they are kept properly inflated and not abused). I fully admit that I am basing my past experience that doesn't include either exact model, but I had owned both brands.
Tireguy,
so what DO you think of the Yoko Avid V4S? are they as good as they advertised to be??
I have a some what bias opinion having being f*cked over a few times by yokohama, they don't stand behind there products the way any of my other suppliers do and to me that is unacceptable. They do make some good tires, the A032R's are great for what they are as are the Advan 048's and since there is no waranty its impossible to get screwed. I also have had horrible experiences with multiple AVS sports coming apart, and yokohama not standing behind there products. So I don't really trust them much.
Tireguy,
Thanks for the insight. You have me looking into the Turanzas now. Just to be clear, you think they would be superior to the Yoko Avid V4S tires in the dry, wet, and snow? Also, what about the fact the OEM tires have a 93V load rating (and the XL rating) and the Turanzas don't. One last thing, what do you think of the Dunlop SP Sport 5000 Symmetrical, Sumitomo HTR+, and the Pirelli P7000 Supersport tires?
Tireguy,
The Dunlop's really aren't bad tires, they have are fairly well built. Though I don't think they are going to hold up well. They may offer better winter traction then either of the aforementioned tires, but they will not be "good" in winter, and they won't be as good in the dry. Probably on par with V4S in wet. It offer's a lot of sipes but nothing special, so chances are they are going to squirm a bit more then the others- and this will become more apparent as they wear. Also heal and toe wear will be an issue if you neglect them in any way for any period of time- and maybe an issue even if everything is on the up and up.
The sumitomo is not even close to the level of any of the other tires discussed hear. Unless money is your only factor(and you probably could find cheaper if you really wanted to) then these are not worth it.
The pirelli's are pretty good, they are a little louder then all the other's and get even louder as they wear. The offer fair dry and wet performance when new, wet traction decreases a LOT as they wear. They claim this is an all-season but it is no safer in winter then anything else mentioned here. These have been on the market for a long time(if they are even still available) and at one time offered something no one else did. Though times have changed and now this niche market is very competetive and there are many other choices that are as good or better. They are not as responsive as the dunlop's or turanza's.
Did you get the AVID V4S tires yet. I'd like to know what your impressions are. Anyone else purchased these tires yet. For me, its between these and the Turanzas. Any advice on places for best prices would also be appreciated. Thanks.
Tireguy,
Thanks for the info. Just curious though, why don't you like the Sumitomos? Is it that particular tire or the whole line? I assume you know they are the parent company of Dunlop, right? I've had several sets of the now discontinued HTR-4 tires (on both a Prelude and a Civic) and really liked their balance of handling and duribility.
I just changed out my stock tires, as well. But, on my Accord, which were crappy and expensive Michelins. I bought Yoko Avid H4S's. I bought the H because I was looking for something under $100 /tire for winter only. I'll be buying rims and summer tires when it's time. They have made a huge difference from the marshmellows that were stock. Would have liked to get something with a little stiffer side wall, but for under $300 (tirerack.com) I am happy with the performance on these. Anything would be better than the Michelins!! The only good thing I could say about the Michelins is that they lasted 60K+.
Tireguy,
They are in a round and about way a "parent" company of Dunlop, though they share NO technology. Sometime in the 70's sumitomo bought the dunlop company, however in 2000(or was it 99?) Goodyear bought Dunlop North America and part of Europe. Even though Goodyear now owns Dunlop they are two very seperate companies and to the best of my knowledge share nothing more then distribution. So Sumitomo, or Goodyear have little if any influene on the actual products produced by Dunlop, FWIW.
The funny thing about tires(like most any other consumer driven product) you can find someone to tell you that product "x" is the best available and someone else will tell you its the worst available. If you have had experiences with them(sumitomo) in the past, then I am happy for you, and enjoy them. However, with my experience I would NEVER run them on my car or anyone else I care about, nor recommend them to a customer. But like I said that's just my experience.
Yoko Avid V4S
Yoko Avid V4S
I have these on the CL and love them.
Originally Posted by slobeatz
Tireguy...how much do the nokian's go for?
Originally Posted by ClutchPerformer
Hey Tireguy,
What do you think about the Continental ContiExtreme Contact as an all-season tire? Thanks for sharing your knowledge!
As a true all season it falls short, I recently put a set on a customers 04 E320 w/sport package, against my recommendation I might add. I was not impressed with the tires, but they were fairly inexpensive. They use a silica based compound which is fantastic in wet(paired with a direction hi-void, by todays standards any way, tread makes for a tire good in rain), the sacrafice is made on wear and winter traction. You can make a silca based compound work well in snow, but its difficult and expensive. Silca also acts weird at lower temperatures, so you may have a loss of traction on dry and bitter cold days. There is no proof to this but it seems that silca based compounds also get louder and lose a bit of traction as they wear, unless they use anti-hardening agent in the compound which to the best of my knowledge Bridgestone is the only company to do this and only on there Uni-T AQII tires. Other then that silca is GREAT! There are more advanced forms of silca that are addressing these short comings while adding even more benefits, but this cost a lot. Silca is basically sand and to change it you have to alter it molecularlly(sp?), though down the road I suspect they will master it as they have carbon black based tires.
There was something very specific about the conti's that I didn't like(other then there performance on the vehicle) I think it was there siping, it only went half way down. While this is cheaper, it makes for a tire that handles/performs completely different when half wore. They were loud on the car(louder then the factory michelins), and seemed to lose some responsivness. While they MAY be better then the factory michelin's in rain and snow now, that may be a different story as they wear. That being said they don't qualify for the montain snow flake pictograph, so they are not truly safe for winter conditions.
There is only one tire available in north america that is a true all season tire and that is the Nokian WR. There is a lot of information about this tire already here so just search if you are interested in knowing more. If you don't find what your looking for let me know and I will do my best to help you.
HTR4:
SP4000:
saberlove
03-11-2021 09:29 AM
