The Tire Selection/Wheel Size Master Guide
#163
J M U ... DUUUKEESSSS
sorry for the newbie question....
Will 18x8, +40, 5 x 114.3 rims with 245/40R18 tires fit on a 2007 TSX? Will it rub?
I am about to purchase a 2007 TSX, can anyone provide more insight on the TPMS? What's the affect of putting on some aftermarket rims/tires? Can I take out the TPMS sensors out of the stock tires and install it in the aftermarkets?
Thanks!
Thanks!
#164
I shoot people
...so, I'm thinking about trading my 02' TLS in for aTSX , but right now, I have a set of rather expensive wheels they are 19x8 +51mm, anyone have 19's with a +51mm offset?
#165
Unauthorized User
I have 19x8 +49offset and they fit the TSX just fine. the OEM wheels are 17x7 with +55 offset.
#166
Bye TSX, hello domestic?
#167
I shoot people
Originally Posted by xizor
they'll fit perfect, https://acurazine.com/forums/showthr...ght=work+vs-ss
#169
I shoot people
Originally Posted by VegaTSX
Did you read my post up above?
opps, my bad , I didn't
#170
I ordered a set of rims that are 17"x8" w/ a =42 offset. I tried to link into the tire calculator... but it didn't go. I will be running the stock tires 215/50/17 since I just got the car. Are these going to stick out an make it look like a 4x4? I am nervous since I didn't realize that they were 8" wide.... Am I screwed?
#171
Don't know if anyone has discussed this in the 7 pages, but TireRack lists our OEM tires at 819 Revs/mile, not the 792 as calculated by Dan in the first page. If someone wants me to update, I will.
#172
RSX to TSX
hey guys, i just ordered some wheels...
Work Emotions XT7's in 18x7.5+48
what size tire should i order? I need summer tires.
i was thinking 225/40/18
and thinking of the Bridgestone Potenza RE050A
whats the difference between them and the Potenza RE050A Pole Position's?
anyone know
i was going to order off of tirerack because its pretty cheap off there.
anyone know
#173
hey guys i tryed that calculator link but its a dead link, but anywho i wanted to know if 19x8 with a +46 offset be fine? I dont really want it to be flush but in a bit. any input would be great help
#175
Would 19x9.5 +42 wheels with 235/35/19 tires be a problem? No drop at the moment but if were dropped a little, how low could one go before it becomes a problem?
#177
blah
19x9.5 is too wide for the front. Your tires are going to be pretty damn stretched. I would get something less wide in the front.
Are you going for the staggered fit?
#181
Is anyone rolling on wheels with a 38mm offset? If so how far past the fender does it stick out? I was thinking about getting a set of Enkei J10`s that are 18 x 7.5 with a 38mm offset. I need some input please.
#182
TSX Sold! Hello STi!
With 225-40-18 tires, you'll be sticking a little outside of the fender... keep it to at least a +42mm offset and 225 rubber, and you'll be flush.
#186
B A N N E D
have rsx type s 17's (45mm offset) with the oem tsx 215/45/17 pilots
how much WIDER of a tire can i go without sticking out or being too big on the rim? 225? 235?
should i go with 50's again or look at a 45? these need to be all season... wisconsin snow doesnt like low profile tires too much either.
thanks
thanks
#187
another wheel/tire combo?
Hey, I have been searching and haven't seen anyone ask about this wheel and tire combo, I have been looking at the TSW Laguna in 19" x8" with a 40mm offset. The tires I was looking at are 225/40R19s.
I want to have an Eibach Prokit installed.
Just worried about the rear tires rubbing, any thoughts or opinions would be great.
Thanks.
Thanks.
#190
They're not "so wide" - they're a perfect fit.
The design of a tyre will have an effect on how flush or not it sits with the rim - it's a design feature to help minimise kerbing the wheel.
But unlike the Euro Accord, the TSX runs a different width/sidewall ratio, so you really ought to check www.carbibles.com/tyre_bible_pg2.html and compare the standard tyre size with the new size planned for. Keep within ±2%, tighter if you can, to maintain speedo and odometer accuracy.
#191
We should amend the first post in this thread to show that the stock Michelin HX MXM4 tires that come on the TSX have a load rating of 1433 pounds (XL rated).
Therefore, all replacement tires, no matter their size, should be rated at or greater than 1433 pounds MAX LOAD.
Check here for more information:
http://www.tirerack.com/tires/Spec.j...D15VR7MXM4HXXL
#192
too many pages to search, but is a 235/40-18 too wide for a 7.5" wheel? I know OE is 7" and according to the table, if I want a slightly wider tire I would have to be between 215 and 235, but I don't want mamouth tires if the new wheel is only .5" wider. I just looked at a newer mustang with 235s on it and they look REALLY wide, but they are on 8" wheels. Any thoughts? thanks.
#196
ok...question...someone with knowledge please reply.
2008 tsx...aspec suspension kit already installed.
looking to buy ronjon inspyre (18")....will 235x40x18 (recommended tire from ronjon) rub with my drop from the a-spec suspension?
thanks in advance guys.
#197
17781708
#200
that's interesting, b/c ronjon suggests a 235 tire for their 18x7.5 size inspyre rims??? doesn't make sense....i think i'll have to go with 225/45/18 instead, however, it's going to throw off my spedometer more (approx. 1.6%) vs. only 0.2% going with 235x40x18
