Tire Mismatch Issue
'06 TSX 6MT
Tire Mismatch Issue
I did my research and decided to go for a set of Continental ExtremeContact DWS to replace my Bridgestone Potenza RE960AS tires (on 2006 OEM wheels).
After they put them on, I noticed that they put on 215/45/17 instead of the 215/50/17s required. They said they'd put the right ones on this week, but now the Continentals are out of stock until May.
Question is this:
Do i live with the 3.3% difference in the speedometer/odometer for 3-4 years, or do I pick another tire?
I'd go back to the Bridgestones but this winter they really disappointed me in the snow- as bad as the OEM hockey pucks the car came with...
Question is this:
mrgold35
Can you go back to the Bridgestones until the Continentals come in? I have the RE960AS on my 06 and I love them compared to OEM. I don't get any snow in Albuquerque so snow/ice traction wasn't a problem for me.
The Continental ExtremeContact DWS are fast moving up my list as an replacement tire for the TSX. I might even try them on the wife's RDX at the end the summer.
I had an 97 Honda accord and sears did the same thing and placed the wrong tire size on the car. The speedo was over about 2 mph and my gas mileage stayed about the same. I kept those tire on the car for about 5 years.
3.3% over 4 years can add up to a lot. I would wait until the correct size comes in or shop on-line for tire retailers that might have the correct size(discount tire, tire rack).
Modding newbie
I'd bring it back and have them replace them with any equal or better quality tires at their expense. They screwed up and will have to fix their screw up.
I would also file a complaint with the local BBB. Mismatching all 4 tires is nothing short of stupidity.
I'm inclined to agree. If you think about it, this is a huge screw up on the part of...... whatever kind of car place this is (kind of like having your house painted the wrong color "sorry, we didn't notice it was beige not white") . I'd bet they installed what they did because they didn't have the right ones on hand (and wouldn't till May). Aside from just looking small (215/45 is a pretty small tire), you'd just do better all the way around with the proper size tire.
Modding newbie
In fact, at over 3% too small, you could have problems with VSA and ABS systems, which would turn into a safety issue. If you got in a wreck because of a VSA or braking issue, they'd be liable.
2006 DGP Sold 10/24/2012
Check the load index on those undersized tires... looks like it is 91. Spec is 95 for our cars. Not only are they too small but they are not rated high enough for the weight of your car.
Point out the liability issue to the tire dealer and demand they find the correct size immediately.
I did a little more research on the XL versus standard load rating, and found some interesting data. The following applies to two tires of the same size. Up to the standard load tire's maximum pressure (35 psi), the load rating at a given pressure for both tires is the same. It's only at higher pressures (36-41 psi, the XL tire's maximum pressure) that the XL tire enjoys a higher weight rating. So..... since the TSX's recommended tire pressures are 32F 30R, it would seem to me that the XL tire is of no benefit. Go figure.
i dont understand how it would take over a month for them to order new tires? thats a loooooooooooooong time
yea i would demand a partial refund for them waisting your time or some benefit from them like free alignment or something like that
cycdaniel
12-17-2019 10:58 AM
