Tien SS Coilovers
Tien SS Coilovers
Do Tien Super Street Coilovers allow you to change the height without going under the car, if so how. Why is it so much better than the Eibach Pro-Kit and more expensive? Ur
Just dial 1911
1 Post
No, you cannot adjust ride height from within the car for any of the Tein series (not sure about other coilover brands). You can adjust dampning only within the car with the EDFC controler on the SS and Flex series.
Tein's and any coilovers are going to be more expensive then just springs because your getting a strut and a spring all in one package.
Bye TSX, hello domestic?
The FLEX costs more due to the fact that it's a complete unit including top mounts and all hardware pre-assembled; it also includes adjustable lower mounts as well as the threaded lower perch. I paid $1290 shipped for mine.....
Also, no EDFC for the SS on the TSX. Not enough clearance for the motors.
Just had my Tein SS coilovers installed this weekend. You need to jack up the car to adjust the height just for the simple fact of getting the weight off of the car. As far as adjusting for a a firmer/softer ride, you can do it pretty easily if you drill 2 small holes in the plastic behind the rear seats for the rear, and just popping the hood for the fronts. I will have picks soon. It dropped my car about 2 inches front and back. It sits so sweet now. No noise porblems due to JTso's meticulous installation techniques. The ride is stiffer than stock, but I am still tunning it in. It handles soooooooomuch better than it already did. Will have pics in the next day or 2.
They were about $900 shipped. I upgraded my order from the basics so I could adjust the dampening, and glad I did.
I agree with Lanny.....Using just springs is not even worth comparison.....if you can afford the full coilover vs the springs...do it!
Originally Posted by LannyM
Another JTso install? OMG, Johnny, do you do one every weekend ?
Master Graphic Artist
Originally Posted by CJams
Funny story (don't mean to hijack)...But as JTso was installing we were chatting about our work and found out we work in the same building for the same company. And I met him through this site. Crazy huh?
Rep'n Taxbrain.com
I wanna get Tein SS and some headers. You sure are lucky. I wish I had JTso to install for me!
Has anyone had any problems with the Tien SS coilovers, I heard that some people were hearing clanking noises when going over bumps... Has anyone experienced the same type of thing? Where did you get your Tien SS's for $900 shipped?
It was ABOUT $900 shipped. Most likely a FEW buck more, but I bought a few things with it and was given a good package deal. It's an around about price. I haven't had a chance to realy look at my invoice yet. I got the package and was so excited to get it I forgot about the invoice. I went through MR.HEELTOE! He did give me a better deal than anyone else I found. So I suggest trying him first! Don't hold him to that price since I may be wrong, but not far off! I ordered it on Thurs, had them by Wed, and they were in the car by sat @ 1:30. Fairly painless and fast!
Rep'n Taxbrain.com
^^ His was installed by someone very experienced though. I'm thinking the install has something to do with whether or not there is noise.
JTso, is there anything special that you did during the install to help prevent noise?
Thanks In Advance.
Thanks In Advance.
Nothing special. Just follow the tightening sequence and torque spec and make sure metal sleeve (item #4) is installed center of shock bushings (item #2), leaving space at the top and bottom of the bushings. Otherwise, the metal sleeve can come in contact with washers (item #1 and/or #3) causing pontential noise problem during compression or rebound. If the top bushings are worn out, replace them. And take your time to inspect your installation.
Originally Posted by JTso
Just ordered my TIEN BASIC kit from MrHeelToe seconds ago and should be receiving it in a week, I'll keep you guys posted and I'll take some before and after pics of the car...
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
4drviper
09-23-2015 07:42 PM
