To those with offsets lower than +45
When going from an OEM offset of +55 to a noticeably lower offset (+40 to +45), did you notice any changes in the steering qualities?
Lowering offset increases the scrub radius, which affects on center feel and the steering wheels tendency to recenter itself.
Have any of you noticed any subtle or obvious changes?
Aamir
Aamir
Bye TSX, hello domestic?
Aamir
Aamir
Originally Posted by xizor
You will get more torque steer w/ a low offset and grippy summer tires. It also gives a lot more feedback, which is good or bad depending on how you like to drive. I don't think it changed the recentering of the steering however
What offset did you go with?
Which which do you have on the car right now?
On my Type-R I noticed a large drop in "return to center" and on center feel when I switched to lower offset wheels and new tires. I am trying to figure out if it is more a fault of the tires or the wheels.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
17x8 +45 (oem TL) 235/45/17 w/ oem rubber, drives normal but has more road feedback w/ the wider patch. Going from 215 to 235 is a big jump, the steering feels more weighted which I like.
Originally Posted by CL9projektz
any rubbing with the 235's? i noticed that youve got quite an aggressive drop which is why im asking.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
