Which Tein System is for Me?
Old Mar 1, 2007 | 10:12 AM
MrHeeltoe's Avatar
Former Sponsor
http://heeltoeauto.com/httech/YaBB.p...1172765411/0#0
Stay tuned to this link to always get the most current information on these systems. I am going to be changing the content periodically to reflect new systems, and new concepts. Will add pictures as well.
Originally Posted by mrheeltoe
I am making this article in response to an overwhelming number of times I have to answer this question. I am going attempt to make this posting grow to reflect more suspension items in Tein's lineup. Right now, it should give you a little insight into which direction you should go!
Basics - For the customer who wants to lower the car, improve handling, and retain a relatively nice ride. Most times the ride is comparable to stock. Over certain roads a difference can be felt. This suspension makes the car feel more attached to the road.
SS - Same thing as Basics with the ability to adjust stiffness. There are 4 reasons to get the SS over the basic. 1- You have extra money to spend. 2- You are really concerned about ride, so you want to soften it up making it closer to stock. 3- You are really interested in performance, you want to be able to dial in the shocks where you feel they handle the best. 4- You want your gadgets to have more tweakability.
FLEX - FLEX are for the person who wants maximum handling with a ride that is still acceptable on the street. These have a higher spring rate than the Basic/SS. These shocks and springs are designed for a higher performance level. This also means they will ride firmer than the others. Upper pillow mounts are included, which increase responsiveness and linear feel of suspension, but also make the ride feel harsher (similar to effect of installing low profile tires). The Flex also have a unique lower bracket that facilitates changing of the damper length. This gives more height options and allows for spring preload. If maximum lowering (3"+) is your goal, the FLEX will work. These adjustments also allow for greater track tuning.
EDFC - Simply allows you to adjust the firmness of the damper from inside the car. Not always compatible with all cars and all adjustable dampers. On the TSX it works with the FLEX and not SS due to clearance issues on the car.
Old Mar 1, 2007 | 10:52 AM
jlukja's Avatar
Marcus, did you leave out the CE on purpose?
Old Mar 1, 2007 | 11:12 AM
DAYTA's Avatar
Did you mean the Tein CS?
If so, I would think it's because they are not offered in US (import only), so they are not as readily available as the 3 main Tein setups.
Old Mar 1, 2007 | 11:15 AM
MrHeeltoe's Avatar
Former Sponsor
CS, and no. I just had not had time to put it in.
Although, to quote myself
Old Mar 1, 2007 | 11:31 AM
LoveMyTL-S's Avatar
Nice write-up. That should answer some questions for members. Thanks for taking the time to clairify the differences in the Tein Coilover models.
Old Mar 1, 2007 | 02:18 PM
SeanS627's Avatar
Not Driving, Just Posting
excellent work marcus
you were a big help in helping me decide on the FLEX and even though most people warned me that their women didn't like the ride, my wife is riding around at full stiff(edfc motors mounted, but not wired up) and she is fine with the ride
thanks again
Old Mar 1, 2007 | 02:33 PM
jlukja's Avatar
Yes, I meant CS.
Old Mar 1, 2007 | 04:12 PM
hfkuan's Avatar
whats the approx. drop of the basics? Are these also height adjustable?
Old Mar 1, 2007 | 04:39 PM
ACURA TSX'D's Avatar
Thanks marcus for informing us on the various types of setups that Tein provides for us. I know i've been one of the many members of this site that has contacted you via email and it's much appreciated to know that someone out there has the initiative to provide us the info that's most important to us regarding suspension.
Old Mar 1, 2007 | 09:52 PM
MrHeeltoe's Avatar
Former Sponsor
The Basics and SS will drop the TSX about 2" in the front and about 1.7" in the back. That yields about 1 finger gap all the way around. Some people are afraid of the 2" in the front, but this drop is nice and even looking, rides excellent, and offers much improved handling. Ground clearance is less, but still plenty adequate. Overall, I think it is the perfect drop. But you have about 3/4" adjustment up or down without hurting the ride.
Old Mar 1, 2007 | 10:50 PM
TodaSi's Avatar
Reading this makes me a little sad. I guess we have come to the point where performance is lost and aesthetics reigns supreme. I may be miss reading Marcus' article but it does drive the point of looks...which is unfortunately what most (I'm guessing here) customers want. Nothing against Marcus (who is and has been an awesome vendor) but have we all lost the point of coilovers? Coilovers are to balance the vehicle via cornerbalancing/cornerweighting. How many people on this site have actually cornerbalanced their car after they installed coilovers?
Old Mar 1, 2007 | 11:57 PM
Zoopa's Avatar
The biggest disappoint of the TSX are the stock dampers. While the car looks like it is riding a little too high, the 2" drop, conversely, may be a little too low.
My concern would be going from a ride that is unsatisfactory because the stock dampers do a bad job of compression and rebound to a ride where every little bump is felt in the cabin.
Sounds to me that the TEIN Basics or Comfort Sports are a better choice if improving ride quality takes the priority over looks.
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
knight rider
Mar 4, 2016 08:59 AM
lanechanger
Oct 13, 2015 10:56 AM
SiClone
Oct 1, 2015 10:22 PM
jmaxima03
Sep 27, 2015 10:22 AM
