Tein Flex or Tein CST?
#42
Originally Posted by grenas17
I got 225/40/18 tires because it is close to the matching size for oem.
Ya i knew you could drop the CST's as much as you wanted, I was just wondering if I would have had rubbing issues.
sorry, but you're wrong.
Specification ..Sidewall ..Radius ..Diameter ..Circumference ..Revs/Mile ..Difference
215/50-17 .....4.2in .......12.7in ....25.5in ......80.0in ..............792 ..........0.0% **OEM**
^above is OEM
225/40-18 .....3.5in .......12.5in ....25.1in ......78.8in ..............804 ..........-1.5%
you're now 1.5% smaller than OEM
vs. my suggestion:
235/40-18 .....3.7in .......12.7in ....25.4in ......79.8in ..............794 ..........-0.2%
where you would only be 0.2% smaller.
225 is not the best size for an 8 inch rim.
and it's not the closest to OEM either.
I guess you did your research wrong.
#43
Thanks for the clarification MMS, but i already knew that information.(checked the wheel size choose guide).
I didnt mean that in a disrespectful tone at all. I knew that 235 would fit better, but I didnt want to have a big sidewall, I wanted a smaller one so I would be able to drop it more and not have a lot of rubber coming over my rim.
Appreciate your info though MMs
#45
Originally Posted by samnguyen
i just have one question, if you put the CST and the rim on the car; will it void the warranty?
#46
Magnusson-Moss Warranty Act
No aftermarket part or accessory that is properly installed on your vehicle will entirely void your original vehicle manufacturers warranty. According to the provisions in the Magnuson-Moss Warranty - Federal Trade Commission Improvement Act, It is the dealership's responsibility to prove that your modification directly caused or affected the failure you are trying to resolve. With that said, some dealerships are more performance-oriented than others and are more willing to work with customers.
Warranty-related materials, published by the new vehicle manufacturers, state that the installation of aftermarket parts have no effect on the warranty unless such equipment causes the problem that leads to the warranty claim. Nonetheless, some dealers have improperly denied warranty claims even though the claim had nothing to do with aftermarket parts. I.E., just because you install an exhaust system, your suspension failure warranty claim cannot be denied. If you experience a problem with an uncooperative dealership, point out the provisions of the this "FEDERAL ACT". For more information call your vehicle manufacturer or click on the link above to go directly to the Federal Trade Commission's website to find out more about this law.
#48
^above is OEM
vs. my suggestion:
^above is OEM
vs. my suggestion:
More rim width reference here -> http://www.tirerack.com/tires/tirete...#rimwidthrange.
BoricuaTL
04-08-2016 01:08 PM
lanechanger
10-13-2015 10:56 AM
4drviper
09-23-2015 07:42 PM
