tein CST for tsx
Marcus of Heeltoe can get them for you. I don't think anybody here got them yet
https://acurazine.com/forums/showthr...highlight=tein
What chu talkin 'bout, lito?
We've been calling them the "Tein CS" around here, since the name is Comfort Sport.
I gotta pick a weekend soon to install these. Time for the Flex's to go back on the shelf for a while.
Anyone know if TEIN ever plans to produce Monoflex's for our cars?
http://www.tein.com/mfpdamp.html
I want to try a softer adjustable suspension. I'll prolly pick one and sell the other later.
Oh, and gotta do my mod-ly duties... moved to tires, wheels, and suspension.
I've had these on for about two weeks now and they are great. I went from A-Spec to Tein SS to this setup and I feel this is the best compromise. There is a tiny bit more body roll in the turns and nose dive etc. But on the corners I feel I can push it almost as hard as the SS (When at full damper stiffness). I am looking forward to installing the EDFC. By the way, the instructions are completely in Japanese and I could find no reference values for the spring seat so I am about 1.75" up from where the threads start (same way you measure the reference hieght on the SS's). This gave me the perfect drop I was looking for, I am measuring about 14", maybe a little less, from the center of the wheel to the edge of the fender.
How do they compare to your A-Spec? Worth the extra $? Please try to describe how they ride/handle better.
Originally Posted by TodaSi
That's not enough information.
Hope this offers more help but I have to go...
Part number: GSA42-F1SS1
9kg/mm front
6kg/mm rear
189,000 yen
What's the lowest setting you can have on those CS dampers? Initially i was considering purchasing the Basics or SuperStreets however, after reading your post i feel maybe those CS dampers is exactly what i'm looking for. I want a lowered car with improved handling but not sacrificing ride quality. The only question i have is what is the lowest setting you can have on those dampers? The ride height i'm looking for is 2.0in front and 1.9 to 2.0in in the rear. Is it possible i can go any lower than that w/ those dampers if i wanted to?
However, they can go lower (or higher). The limits of adjustability are: -20 to -70mm for the front and -10 to -50mm for the rear. That's -2.7" for the front and -2" for the rear.
Originally Posted by SimpleWhite
looks like it time to sell those flex
So, what noises would you describe that SS's as having that these don't? Have you had any noises (pops, clunks, squeeks, etc) from the new CS suspension?
In comparison to the A-Spec I would say that the handling is much improved but you also get smoother ride over bumps. I felt the A-spec was oddly firm going over small bumps and gave little performance advantage over stock. This setup is just the opposite. When riding in the car over a old bumpy in town road you would never think the car was lowered or on a performance suspension. But when you hit the windy highway it feels tight and smooth with much better performance than the a-spec. It really is the best of both worlds, excluding track expectations. Cornering feels similiar to my SS's and is very stable with very little lean. There is a little more initial lean than the SS's going into the corner but the dampers seem to quickly get firm and remain that way throughout the turn. Basically, it is a much better quality damper set up than the a-spec and you feel it and is worth the extra money in my opinion. Not to mention the adjustability and EDFC compatability. In a nutshell, this suspenion is exactly what the A-Spec is missing in terms of smooth ride and performance handling and what I didn't like from the SS's in terms of bouncy ride and some certain noise's, vibration's, and cabin creaks.
yeah but they are not independently height adjustable which means you cant go as low.
although the picture is evidence of not having the "full length adjustability" part
tein says it has it. whats the deal?
http://www.tein.com/cstdamp.html
"C. Full-length adjustment system :
Threaded shock bodies allow for minute adjustments (1mm increments) to the ride height. For optimal handling, we recommend setting the vehicle to no more than +/- 10mm from the suggested ride height."
Hey did you use the rust proof spray? I think the workers at the shop that i had my install done at allegedly stole it, but no biggy. When i have passengers in the rear and on full soft you can hear the clunking of an edfc motor in the rear, but on full stiff it goes away. Also when the car sits overnight in cold weather, the next morning the suspension squeaks, but after the car is warmed it goes away. Those are my only complaints, they're hardly anything to complain about, but just giving some feedback.
Originally Posted by aaronng
The CS are recommended to be lowered from -30 to -50mm on the front and -20 to -40mm on the rear.
If i go lower than recommended settings, what are some of the repercussions that can occur? Will the ride quality suffer? WIll the longevity of these dampers decrease ?
$1300 from Mr. Heeltoe ain't that bad at all. That's actually a pretty damn good price considering these coils are EDFC compatible.
I wonder, where are you even supposed to spray the rust proofing spray on? The springs and perches? The threads? There isn't much in that bottle.
I was kind of thinking it was for the the main damper body and the perches. I don't know if I would spray the springs... could lead to noise problems in the future. The only things I was thinking about spraying were the bolts.
Darn, I just finished installing my A-Spec's. After hearing about how much better the Tein CS's are compared to the A-Spec's I really one the tein's. How much are the Tein's with S& H???
For those Tsx AT owners how would you rate the Tein's from a Scale of 1-10 comapred to the A-Spec's ???
cuteguy1414, they're on! I haven't had any time to get some pics or do a good impressions writeup, as I'm traveling this week and next. I will be sure to do so later.
mav3556, these are significantly different than the A-Specs. I don't have any of the tech info on the spring and dampener ratings around me now, but additionally these allow the adjustable drop and adjustable shock dampening. Other than that, the biggest difference is price, these will cost you ~$900 more than A-Spec.
